Question about Daewoo Refrigerators
How do you defrost a daewoo de x22d3tnp 2 door fridge freezer
    Top Expert:
  • Daewoo Master
  • 8,204 Answers
Posted on Dec 04, 2016
My Daewoo American fridge freezer is not making ice in the ice compartment and food have started to defrost but you can hear the fridge freezer working
How old is the fridge? If it is old I suspect the compressor is not functioning as it should. Things to check before calling the repairman or buying a new one: The thermostat setting. Be sure there are no air leaks around the door seals.
Jan 10, 2018 | Daewoo Refrigerators
My Daewoo FR-291 fridge with freezer at topleaks 1/2 cup or so a day & onto floor sometimes. Hired one for $150 as told to turn ours off for 2 days. Leaked nxt day again. Thxs NZ
a thorough inspection of the tubes, filter, solenoid, ice maker and water dispenser should reveal the leaking component
also a thorough inspection of the defrost drain, drain tube, and dryer pan
Apr 08, 2017 | Daewoo Refrigerators
How to identify why my Daewoo ERF-364MNL fridge freezer is warm
This is a fairly common problem with most Frost free Fridge freezers. The system relies on regular automatic defrosting, and if there is a fault in that, the cooling cycle is seriously affected.
The problem could be as simple as a blocked defrost water drain tube, or more complicated such as a failed de-frost heater, defrost timer, or drain tray heater.
To check and repair any of them, is quite an involved process which involves stripping a lot of trim, and other parts just to get to them.
I would suggest that you get a qualified Refrigeration Engineer to repair it.
I hope this helps?
Feb 08, 2016 | Daewoo Refrigerators
Daewoo frsu20iai freezer builds ice at bottom and starts to defrost some items?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Aug 25, 2014 | Daewoo FRSU20IA Freezer
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
Bosch Fridge Freezer: Fridge Not Cooling
Your refrigerator's cool is provided by your freezer section through a damper - there should not be excessive frost on the cooling coils - the most common problem is a defrost timer - are you absolutely sure the noise you hear is the defrost this is the first thing to check, defrost control and its components, is it properly shutting off or stuck on during operation - the next thing to check is for possible sealed system problems / small leaks, door gasket seals, etc.
The fact that it started to work once you manually defrosted is the key here - an over forsted evap will cause the problems you describe most commonly - so have your defrost system checked completly and properly - that should solve the problem. followed by checking door gaskets, damper and sealed system - if only part of the coils are frosted as opposed to the entire surface, that usually a clue to sealed system leak - yes 10C is quite warm for a refrigerator. It should be between 34F-40F, optimal is 34F. And freezer section no warmer than 10F, optimal at 0F (-18C)
Aug 24, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
Need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Jul 14, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
47 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
