Question about Sylvania Televison & Video
Please help me with a salvania TV. Pic all white. You can pic and hear sound but then it cuts off
  • Marc Allen
    Marc Allen Dec 04, 2016
    The salvania TV is all white.. You can see picture three the whiteness and hear sound.. It then cuts off
    Top Expert:
  • Sylvania Master
  • 75,599 Answers
Soundsl like ABL circuit problem. The service work to this kind of fault, will be somewhat skilled. Best is to contact any service technician. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 05, 2016
SOURCE: no pic, no sound
Hey Wilt: We had the same problem, for the same model of Toshiba TV. Had it repaired yesterday. Turns out the problem was the power supply (P.C.B). The total cost was $192.66 Canadian funds (taxes and labour all in). Our model was 6 years old, buts its playing like a brand new unit now. Hope this helped ...... Good luck
Posted on Nov 02, 2006
  • 86 Answers
SOURCE: If i turn off my tv it wont turn back on
This problem is either the TV's software or how the mainboard is distributing power so instead of just unplugging the TV, try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power/on-off button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Since hardware either works or it doesn't, your issue is either software or power related since you can get it to work so hopefully the power drain will indicate further.
Posted on Mar 25, 2009
  • 87 Answers
SOURCE: NO PIC OR SOUND
YES IT IS FIX ABLE LOOK FOR A SONY SERVICE CENTER, CHEAPER IN LONG RUN. COUNT THE FLASHES IT SHOULD PAUSE AND BLINK AGAIN FROM LIGHT ON FRONT. DIAGNOSTICS FOR THE TECH.
Posted on Apr 15, 2009
Justin9992
  • 36 Answers
SOURCE: No pic, just a black screen w/white grid on it. How do I get picture back on it.
Sounds like they enabled some test mode of the TV. Can you activate the menu using the remote control and see if you can navigate to disable that? How about if you just unplug it from the wall for 60 seconds and plug back in and maybe it will reset.
Posted on Apr 16, 2009
  • 814 Answers
SOURCE: tv goes on fine, sound good and pic green light receptor on tv starts blinking and we lose pic sound still good. When we tap the light on tv pic comes on fine for a while then same thing happens again
This television is having problem with intermittent tuner reception.The tuner is the signal processor for the television. The video section is intermittent. This could be a simple matter of cold solder joints that can occur over time due to heat expansion and contraction.This causes the metal in solder to expand and then when the television cools down, the metal that is expanded cannot contract.The solder joints then becomes intermittent. All televisions suffer from this problem.Since you are able to still able to receive the video signal, there appears to be no component damage. You will need to take this television in to a service center and have them rework the solder on all the areas around the tuner section of the television and any other areas that may be susceptible to the problem due to overheating.You can call Magnavox customer support at this telephone number 1-800-705-2000 and ask them for the location of a service center in your area. Or take it in to a local repair center and have them test and service the television for you. You can also try taking it to a school where they are teaching electronic repair and ask them if they will work on the television for you.They will usually do the work for a cost of parts and a small labor charge. Call them first to make sure they will help you and tell you how you can get the television serviced This may not be the only problem you are having with the television. That is why you need to have it tested first. I hope this information help you with your problem.
Posted on Jun 03, 2009
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
My wii comes on and you can hear the sounds but no picture and i have it all hooked up to the right things but still no pic.help
Hello.
Are you using RCA to connect it (red, yellow, white wires)? Try another port on your TV. The video slot of your TV might be malfunctioning. Depending on your TV, they usually have ports infront and at the back.
Jul 15, 2011 | Nintendo Wii Console
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
Apr 16, 2009 | Televison & Video
Pic bad
Repair the hyper module.... See some of the previous posts for this problem...
Bill
Oct 28, 2008 | Toshiba 42H81 42" Rear Projection...
This Tv is so Crappy...
try contacting funai customer suport at 800-242-7158 they supposedly make ilo tvs
May 26, 2008 | iLO 3200 32 in. LCD Television
Tv pic went blank but still have sound?
gud day..ur tv needs a qualified serviceman.. maybe in the video setion of the PCB theres a coroaded solder..you need a soldering iron and lead to reinforce the coroded terminals..ty
Feb 05, 2008 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
