Question about Kodak EasyShare DX4530 Digital Camera
KodakEasyShareDX4530 states that new sd card is locked when it's not.Any help with this is appreciated.Camera won't format any of my cards. Need help
SOURCE: why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
Posted on Dec 05, 2008
  • 285 Answers
SOURCE: Kodak 7590 New SD card will not format
Is this an older camera? If so it will not support sdhc cards. Sdhc is a 4+ gig card. You will need to buy a card 2 gig or under.
Posted on Jan 29, 2009
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Posted on Apr 15, 2009
  • 8 Answers
SOURCE: 2GB SD card is brand new but camera says it is full.
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
Posted on Jun 03, 2009
  • 3 Answers
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
After having the same trouble, I installed a 1 gb card and it worked just fine. It appears the Kodak C330 won't recognize a 2 gb car.
Posted on Jul 22, 2009
I am trying to format a 4GB SD card for my camera and it will not format
The DX7590 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use cards 2GB and smaller.
Feb 15, 2011 | Kodak EasyShare DX7590 Digital Camera
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
Jun 29, 2010 | Polaroid DVF130 Camcorder
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
SD630 camera states error memory card? New Card 2GB SD Card. Then it states card locked removed card and still says card locked. Will not let me go into format on tools. please answer.Do I need to just...
On the side of the SD card there is a little switch for locking the memory card to prevent erasure or writing. Make sure it is not locked. After that try a smaller size card. After that junk it.
Nov 18, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Nikon Coolpix L11 Memory Card Error
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 05, 2008 | Nikon Coolpix L11 Digital Camera
Card format problems
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
Aug 27, 2008 | HP Photosmart M527 Digital Camera
Sd card will not format
The camera has a limit of a 2 GB card , its built into the camera hardware.
Oct 19, 2007 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
42 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
