Question about Intel 430180-001 - HP Pavilion dv8200 dv8300 dv8400 Series Laptop Motherboard System board
HP baptop bootup problem
I have a lap top. It does not boot up into the window. last mont, I had this problem but it some time boot up. Once it booted up in Window then I press on F8 to restore then it worked. Now the problem come back and it can not boot up into Windows. What can I do.
Plese help me out. Please send me an email via chieu2002@yahoo.com
Thanks for your help.
    Sergeant:
  • 449 Answers
Does your hard disk making noise ? Like retrying tagain and again. If it is, then hard disk require replacement. Otherwise try formating and re-installing operating system in it. (ehteshamhusain@gmail.com)
Posted on Jul 20, 2009
My hp pavilion 9000 dragon notebook takes nearly 4 minutes to bootup
You need to check what is starting up with windows. Everything that is set to start with windows will slow down the boot time. Msconfig via the run command will allow you to deselect non essential services to speed up boot times.
Nov 03, 2014 | Computers & Internet
When the laptop is switched on it goes to the page with start windows normally. when i select it, it goes to the starting page of window xp and then restarts again.
I would suspect damage to the file system and possibly something wrong with your hard drive. Windows loads a number of system files during bootup, and when it cannot find or read these files, it will cause Windows to repeat the process and cause the bootup loop that you are having.
First thing, backup all your data if possible. Second, you can try pressing F8 when booting the computer to access the "safe mode" boot menu. Once in the "safe mode" boot menu, select the option "Last good configuration", and see if the computer boots up.
There are more complicated methods if that does not work, but its the first thing I would try.
Mar 02, 2011 | Compal EL81 Notebook
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
I turn on my lap top HP Pavillion 2000 and all i get is the lights on the top of the keyboard and the screen remains BLACK, it was working fine last nite. I dont know what to do.
Pull out the battery and try to boot it on AC power only, if it boots up turn it back off reinsert the battery and try to boot again, if it does not boot then they maybe a problem with the battery.
Regards
Jul 14, 2009 | IBM ThinkPad T23 Notebook
Booting repeatedly at compaq window itself,it is not takes up WINDOWS OS.
Solution 1:
When you start the system, press F8 and then select "Last known good configuration". If it does not work the first time, try at least three or four times.
Solution 2:
You can try installing the OS again but you will lose the data in your c drive.
Solution 3:
Check with the BIOS configuration, Take a note of the original configuration before you make any changes.
Jan 15, 2009 | HP Pavillion ZV6000 Notebook
Windows XP Unusually Slow Startup
from msconfig you disable all startup item and restart.Also you defragment your hard drive once in a month and use a good antiviruse and scan your pc at regular interval
Jun 23, 2008 | Microsoft Windows XP Professional
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
HP lap top computer
ok this sounds easy when you were putting in your password in system registry bootup you hit the switch screen to use display video back paralel remove the password and reset the boot process parameters back to default this should relieve your problems
im here if you have any other questions about motherboard bootup
at 9pm arizona U.S.A. time ill be back
May 30, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
WONT BOOT UP
with out a cd theirs really nothing you can do....you'll have to get the OS cd and boot from it and repair the boot sector
Nov 11, 2007 | Toshiba Satellite A60 Notebook
Intel 430180-001 - HP Pavilion dv8200 dv8300 dv8400 Series Laptop Motherboard  System board  Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
