Small button that open and closes for dvd has broken at inner tip. Only displays "open" on screen. Is this replaceable?
  • Televison & ... Master
  • 5,309 Answers
Not knowing which model it is, I can only say that if the control panel button is the type that pushes on a control and that it is attached via a moving bit of plastic, then it is possible to solder (melt) the plastic back on. So that the button can once more be pressed. Great care should be taken, as plastic fumes will smart the eyes and you should not breath the fumes in. Use safety glasses and a small soldering iron to melt the plastic.
Posted on Dec 05, 2016
How do I fix my computer CD writer Drawer to make it open.I banged it with my knee when it was open,I pushed it closed and does not open any longer.Its the HP 583 Pavillian model,not new but works wel
Many times you will see a small hole next to drawer, try something thin lika a paperclip & give a gentle poke inside. Feel for a button type spring response.
Oct 15, 2014 | Computers & Internet
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
DVD player is broken and won't open and I have a disc stuck in there
you have 3 alternatives for open:
1) with the button eject or close/open
2) remote control. button open/close or eject
3) with small knife pull out the carrousel for to bring the disk, with carefully.unppluged the power cord.
otherwise you must go to the repair shop TV for fix it
God bless you
Jul 21, 2012 | Philips Magnavox MDV453 DVD Player
Player has sound of the movie but the screen is just white no picture
There is a small button on top when the screen closes it turns off the display. While the movie is playing press the small button with a small pointing object and see if the display shows something on the screen for a few second and then off (you can sometime see the movie playing but very dim). then there is a problem with the switch not switching the display back to normal. Hope this helps...
Jun 02, 2011 | kawasaki PVS-10921 Portable DVD Player
Screen is black like the lens is closed, I believe the inner lens is not opening.
Are you sure your lcd display isn't broken? I don't know if the lens assembly has an inner screen, but if it's not working, it's the gear mechanism that's broken, and will require servicing. Cheaper to buy a new one, on sale, if the cost is too much to service it. A repair shop should be able to give you a ballpark estimate.
Mar 11, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I put a dvd in my portable dvd player and close the lid on the dvd player but it keeps sayin its open when its shut!! therefor it wont play any dvds!
LID SWITCH IS BROKEN, CHANGE IT OR THE COVERLID WHICH HAS A SMALL 3MM SIZE OF PLASTIC MATERIAL WHICH PRESS THE SWITCH WHILE CLOSING IS BROKEN TRY TO MODIFY IT...
Oct 13, 2009 | Goodmans GCE5000 Portable DVD Player with...
Broken Door: Polaroid PDM-0711
You probably cant replace the door because usually they produce a small run of these players and then create a new model and discontinue the old one very quickly. My suggestion is to look if there is a small button around the area the tab would normally go to when you close the door. If you can see this button try to find someting that would keep it pressed down. This tricks the player into thinking that the door is closed. WARNING: This button also activates the laser reading unit so you must have a dvd loaded before you press the button so you dont accidently look straight into the laser unit. IF YOU LOOK INTO THE LASER YOU CAN CAUSE PERMANENT EYE DAMAGE OR EVEN BLINDNESS.
Dec 03, 2007 | Polaroid PDM-0711
Locked tray
Hold the open/close button on the set down until it unlocks and the tray will open in about 10secs.
Dec 29, 2006 | Sanyo DVD-7201 DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
