How to remove lock from print program choices such as plain paper, photo paper, etc
ctf1800
  • 4402 Answers
SOURCE: printer will not print on photo paper
Go into you printer on the control panel select properties> advance button and chose 4X6 and make it letter
Posted on Dec 04, 2007
  • 110 Answers
SOURCE: Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Posted on Aug 22, 2008
venusPCgurl
  • 26 Answers
SOURCE: My HP Deskjet F2100 All-in-one
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Posted on Aug 24, 2008
getbharti
  • 33 Answers
SOURCE: Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Posted on Nov 28, 2008
sherlyn c
  • 134 Answers
SOURCE: Printer will not advance paper.
Choose the media type on print settings that is closest to the type of paper that you are using. Choose the correct paper size too. Try printing again.
Goodluck.
sherlyn c.
Posted on May 24, 2009
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
Paper won't feed through printer. (Lexmark X2690). Can't see anything stuck in printer. Paper won't go down past rollers, but I can't see down inside etc
Loading paper and original documents
1. Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2. Before loading paper the first time, slide the paper guides out toward the edges of the paper support.
3. Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges of the paper.
Align the print cartridges
In Windows
  1. Load plain paper.
  2. Then do one of the following:
    - in Windows Vista, click pattlnk_852008_1527-vista-start-button.gif.
    - in Windows XP and earlier, click Start.
  3. Click All Programs or Programs, and then select the printer program folder from the list.
  4. From the printer folder, click Maintenance - Align Cartridges.
  5. Click Print.
  6. Follow the instructions on the computer screen to finish.
To clean the print cartridge nozzles:
In Windows
  2. Do one of the following:
    - in Windows Vista, click pattlnk_852008_1536-vista-start-button.gif.
    - un Windows XP and earlier, click Start.
  4. From the printer folder, click Maintenance - Clean Cartridges.
  5. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
  6. Print the document again to verify that the print quality has improved.
Oct 28, 2010 | Lexmark Office Equipment & Supplies
Can't select "Plain Paper" when printing from Excel (2008) on a Mac OS 10.6.2. From the Print dialog box, I select "Paper Type/Quality" and attempt to change the "Paper Type:" from "HP Premium Plus Photo"...
Hello, Jon.
There are some problems reported with the printer driver from the HP site, in case you obtained your drivers, there.
Go to the Apple website to obtain the driver and reinstall the driver.
Hope this helps.
Jan 09, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Why does the entire photo printout with a pinkage color overlay when indicating using glossy photo paper, even different photo paper. This occurs with several different programs not just Photoshop. I've...
That happens if you put photo cyan where the plain cyan ink should be, also photo magenta is too weak to be used in the magenta slot. I've also seen generic inks that weren't the right colors.
Jul 09, 2009 | Canon i9900 InkJet Photo Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Won't accept photo paper
Only load photo paper do not mix it with plain paper, this will happen on all printers.
May 03, 2017 | Brother MFC-260C All-In-One InkJet Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Printing paper choices
Aug 19, 2008 | Epson Stylus 2200 InkJet Photo Printer
here is ur fix
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
21 people viewed this question
jasbo
jasbo
