Question about Delphi Audio Players & Recorders
Wiring diagram for Delphi dear 300 or part # 28086273
Duncan
  • 218 Answers
SOURCE: Wiring Diagram
If you could post a clear picture of the back of the radio where the plug goes in I might be able to help you. I need to see the number of pins, their configuration and the shape of the socket. It wouldn't hurt to see the colors of the wires in the plug too.
Posted on Jun 09, 2008
  • 436 Answers
SOURCE: I need a wiring diagram to hookup a Delphi X250
not sure about yours but most common colours are as follows
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Posted on Aug 30, 2009
I'm looking for a factory stereo wiring diagram for Delphl Delco part#12240691 GM Part #22723439 The plug is 24 holes but think it's a 16 wires.
Posted on Jan 22, 2011
Daveatwhips
  • 492 Answers
SOURCE: i need the wiring diagram
Try www.mobileinformationlabs.com for wiring diagrams
Posted on Aug 31, 2011
ladywritr2
  • 948 Answers
SOURCE: Need a wiring diagram for Delphi delco am FM CD player from a 2004 Chevy malibu
According to http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CDMQFjAB&url=http%3A%2F%2Fwww.aircommand.com.au%2Fdocs%2FIbisTechManual.pdf&ei=29JPVfO8NYu9sAWE_YGQAg&usg=AFQjCNEPb_nNaXQsRrD2ZphXVLpRYwECGQ&sig2=cHErjmhdOfyCsep25gpmfw
E4: Indicates lack of refrigerant, or the compressor is not running, or the thermistor is out of calibration. Action: Check that the compressor is running by listening. If it is apparent that the compressor is running, then check the temperature difference across the evaporator. i.e. Measure temperature of return air at inlet filters and measure temp. of discharge air at grilles. This temp diff. should be 14 to 18 C. with fan on hi speed. If temp diff. is less than this, suspect lack of refrigerant. Fit a suction gauge to access valve at rear of unit. See fig 12. On a 35C outside temp. then suction should be 380 to 450Kpa.
Page 2
Action (continued) If the temp. differential is 14C or more but unit goes out on E4 after approx. 30 minutes, please check the actual thermistor temperature by the following procedure. With the inside fan running on Hi. Press Temp down button followed by the mode button. Hold them both in for approx 5 seconds. The amber Lock LED illuminates. Now press the Temp down button and the Sleep button Together for about 1 second. The green Med speed will be Flashing. The display is now reading the temp of the outside coil. Now press the Temp up button once. The Green Hi speed will be flashing. The display is now reading the temp. of the inside coil. This temp will usually be from 5 to 12 C. If it is above 24C. It is another indication of lack of refigerant. If on the other hand the air on /air off differential is 14C or greater then suspect the thermistor itself to be out of calibration. Check the thermistor as per an E1,E2 or E3 failure by measuring its resistance. See fig 19 and referring to table 1.
Posted on May 10, 2015
I have a DELPHI fuel pump but no wire diagram how do I find out what wires go to what wires
Hope you marked the wire colors, on how the old connector was wired? Was the old connector numbered or lettered?
If you want a wiring diagram, I need year--make--model?
Oct 09, 2016 | Cars & Trucks
2004 wiring diagram for sterio
There were three sound syatems used in that model year, a Delphi and (other) with and without amplifer. We would have to know more specifically.
Oct 29, 2014 | 2004 Hyundai Santa Fe
Wiring diagram for a delphi car stereo 2000 volvo factory
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Wiring diagram to many popular brand car stereos are given.
Jul 26, 2014 | Delphi Car Audio & Video
Wiring diagram delphi sa10001
Did you check the fuel pump relay in the fuse center under the hood? Maybe you blew the relay and really didn't need to replace the pump. Did you recheck all the wired connections with a DVOM? Never ever replace anything as important as a fuel pump with out double checking all connection and checking for voltage before putting it all back together. Hopefully you didn't put the gas tank back in yet. Oh and you can swap the relay with one of the others sitting next to it i the fuse center, just remember to switch it back when you're done.
Oct 26, 2013 | Chevrolet 1500 Cars & Trucks
I need a wiring diagram for Delphi Delco 15091316
Oct 25, 2010 | Delphi Car Audio & Video
Looking for a wiring diagram for a delphi radio that was in a Kenworth semi. I am replacing it with an alpine deck
Often you can go on-line and search by model / year for vehicle wiring, which will save you a lot of time...so, either find the wiring diagram for the vehicle or you need to get your voltmeter out and test the leads for proper power and speaker connections. You need to know the constant 12v + first, isolate it so it doesn't short, then the keyed or accessory 12v +. Then the ground - etc.
Sep 27, 2009 | Car Audio & Video
Wiring Diagram
Jun 07, 2008 | Car Audio & Video
122 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
