Question about Kenmore Washing Machines
My Kenmore washing machine model 110 5231090 won't drain in the spin cycle
  • 822 Answers
Pump is blocked,.....
Posted on Dec 04, 2016
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Water will not drain out of the washing machine and won't complete cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Sep 10, 2011 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Sal De
 Brian Main
Brian Main
