Question about Kodak EasyShare DX4530 Digital Camera
None of my memory cards work in my Easyshare DX 4530. The camera states that they need formated even the ones that have been used in it before.
  • Kodak Master
  • 5,412 Answers
Well, in that case, make sure you have backup of the images on them, then format them.
Posted on Dec 04, 2016
My macbook air does not have an optical drive how can I get the soft ware for my kodak dx 4530 on my computer?
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jan 27, 2013 | Kodak EasyShare DX4530 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Purchased new 2gb memory card however camera states memory card is full
Did you navigate through your camera's menu and find the card format selection? You need to format your memory cards when new, and it is also best practice to format the card after each time you use it and remove the pictures you want to keep.
Nov 25, 2010 | Kodak EasyShare CD33 Digital Camera
I have purchased several memory cards and none of them work. i have been to various stores and no one has been successful in helping me witht htis issue. it says formating needs to be done but never able...
Designated memory cards for this camera is : SD-MMC cards of any brands. Kindly don't use pro duo / magic gate memory cards that design generally for Sony camera.
Nov 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
When i put a new memory card in, the camera reads "memory card needs formatting", but when i click format, it does nothing
While some Easyshare cameras will use SDHC cards, the documentation for the Z740 states that it uses MMC and SD cards.
Try using an SD card. If that works, then stay with SD cards. If that doesn't, then there's something else wrong.
Sep 04, 2010 | Kodak EasyShare Z740 Digital Camera
My Kodak DX 4530 says my 4GB SDHC Card needs to be formatted but it won't do it
The DX4530 works with MMC and SD cards. While your SDHC card fits into the slot, it is electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Aug 09, 2010 | Kodak EasyShare DX4530 Digital Camera
Camera states that the internal memory is full even though there is a 512mb card in it. I have already made sure that the auto storage is selected. This is not a new card. I have used it in this camera for...
You apparently took some pics using the internal memory. Now, to get the camera to use the card again, you must format the internal memory with no memory card in the camera.
Jul 24, 2010 | Kodak EasyShare C315 Digital Camera
Camera will not read memory card
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 01, 2010 | Kodak EasyShare DX7590 Digital Camera
Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit warn me that formatting will...
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
Memory Card Slot Not letting it insert fully, seat, lock in place
It may be that you are trying to put it in backwards. It can go in only one way, contacts first. The last bit in "is" spring loaded so it will take a "little" force. If it truly will no go down pull it out, spin it 180 degrees and try installing it again.
Apr 28, 2009 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
