Question about Miscellaneous
Timing marks on 1G-FE ENGINE
SIWALE
3 Suggested Answers
bdmccaffery
  • 96 Answers
SOURCE: how can i loosen the
Air Compress tools, or you can use tool to hold the flywheel in the back the motor. take transmission bottom cover or starter out to get tools into the flywheel
Posted on Feb 11, 2011
  • 75 Answers
SOURCE: need repair manual for 1G FE engine
Link:
http://cgi.ebay.com/ebaymotors/1989-Toyota-Cressida-Shop-Service-Repair-Manual-Book-_W0QQcmdZViewItemQQhashZitem413f2bd695QQitemZ280232711829QQptZMotorsQ5fManualsQ5fLiterature
Posted on Mar 22, 2011
What is the torque specification for the crankshaft main bearing cap on a 1G-FE Engine?
yo will find it here in this PDF that is for entire engine and engine parts and accessories specs ,
http://www.shoarmateam.nl/upload/Lexus/IS200+IS300/manual-is200/Service%20Specifications/m_ss_0008.pdf
the main bearing cap ( for engine block ) is as follows :
60 N.m / 600 kgf-cm / ft-lbf 43 .
good luck
Aug 31, 2017 | Toyota Cars & Trucks
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
Toyota mark ll 1G-FE timing diagram
Shop manual should cover this.
Jul 15, 2014 | 2001 Dodge Stratus
Why are there 4 valve timing marks on a Mazda FE sohc engine
Some marks may not be timing marks. Don't rely on the marks. Find out how to time it by looking at the way the pistons line up and consult an expert if needed.
Jul 10, 2013 | Cars & Trucks
Replacing timing belt on 2003 hyundai santa fe 2.7
"POP" LIKE A BACKFIRE???.....TIMING BELT IS 1 OR MORE TEETH OFF
Jul 30, 2012 | 2003 Hyundai Santa Fe
I need timing marks on 2.2 toyota camry 2000
1. Remove the fan and generator V belt:
tdisline_543.jpg 2. TIMING CHAIN (2az-FE Engine):
Before servicing the vehicle, refer to the Precautions Section.
Drain the engine oil.
Remove or disconnect the following:
Negative battery cable
Hood Right-side front wheel Engine under covers Right-side fender apron seal Front exhaust pipe Engine moving control rod and bracket Right-side engine mounting stay and bracket Accessory drive belt Engine appearance cover Engine wire Alternator Power steering pump, leave the hoses connected Ignition coils Ventilation hoses Cylinder head cover Turn the crankshaft pulley to set the No. 1 cylinder to TDC compression. Align the groove on the pulley with the timing mark -0- on the front cover. Remove the crankshaft pulley as follows:
1. TMC made: Use Special Tool 09213-54015 to hold the pulley to loosen the bolt. Use Special Tool 09950-50013 to remove the bolt and pulley.
2. TMMK made: Use Special Tool 09960-10010 to hold the pulley to remove the bolt. Use Special Tool 09950-40011 to remove the crankshaft pulley
tdisline_544.jpg Fig. Removing the crankshaft pulley-TMC-2.4L (2AZ-FE) engine
Fig. Removing the crankshaft pulley-TMMK-2.4L (2AZ-FE) engine
Crankshaft position sensor Lower oil pan No. 1 chain tensioner Accessory drive belt tensioner
  • Support the engine with a suitable engine lifting device.
  • Remove or disconnect the following:
    Engine mounting insulators Right-side engine mounting bracket Stud bolt for the accessory drive belt tensioner from the block Front cover mounting bolts and nuts Front cover Crankshaft position sensor plate Timing chain tensioner slipper Timing chain vibration damper Timing chain Crankshaft timing sprocket
  • Turn the crankshaft counterclockwise by 90°, and align an adjusting hole of the oil pump driven sprocket with the groove of the oil pump.
  • Fig. Align the adjusting hole of the oil pump drive sprocket with the oil pump groove-2.4L (2AZ-FE) engine
    Fig. Insert a bar to lock the sprocket in position-2.4L (2AZ-FE) engine
    Put a bar in the adjusting hole of the oil pump driven sprocket to temporarily lock the sprocket in position. Remove the nut.
    Remove the bolt, chain tensioner and spring.
    Remove the chain tensioner, oil pump sprocket and No. 2 timing chain.
    To install:
    Set the crankshaft key into the left horizontal position. Turn the cutout of the drive shaft to the top
  • Fig. Align the crankshaft key and drive shaft cutout as shown for installation-2.4L (2AZ-FE) engine
    Align the yellow colored links with the timing marks of the sprocket as shown in the illustration.
  • Insert the sprockets with chain to the crankshaft and oil pump shaft.
  • Temporarily tighten the oil pump driven sprocket with the nut.
  • Insert the damper spring into the adjusting hole, and install the chain tensioner plate with the nut. Tighten to 9 ft. lbs. (12 Nm).
  • Align the adjusting hole of the oil pump driven sprocket with the groove of the oil pump.
  • Put a bar in the adjusting hole of the oil pump driven sprocket to temporarily lock the sprocket in position. Tighten the nut to 22 ft. lbs. (30 Nm).
  • Rotate the crankshaft counterclockwise by 90°, and align the crankshaft key to the top.
  • Install the timing chain vibration damper. Tighten to 80 inch lbs. (9 Nm).
  • Align the timing marks of the camshaft timing sprockets and bearing caps.
  • Using the crankshaft pulley bolt, turn the crankshaft and set the set key on the crankshaft upward.
  • Align the gold or orange colored link with the timing mark of the crankshaft timing sprocket.
  • Using Special Tool 09309-37010, tap in the sprocket.
  • Align the gold or yellow colored links with the timing marks of the camshaft timing gear and camshaft timing sprocket. Install the chain.
  • tdisline_553.jpg Fig. Align the marks of the sprockets and bearing caps to set the No. 1 cylinder at TDC-2.4L (2AZ-FE) engine
    tdisline_554.jpg Fig. Set the crankshaft set key facing upward-2.4L (2AZ-FE) engine
    tdisline_555.jpg Fig. Align the marked link of the timing chain with crankshaft sprocket timing mark-2.4L (2AZ-FE) engine
    tdisline_556.jpg Fig. Tap the crankshaft sprocket in with Special Tool 09309-37010-2.4L (2AZ-FE) engine
    tdisline_557.jpg Fig. Align the marked links of the timing chain with the camshaft sprockets during installation-2.4L (2AZ-FE) engine
    May 21, 2011 | Toyota Camry Cars & Trucks
    I need 1g-fe 2wd A/T ecu 175300-4081 12v pinout diagram pls kindly help me to solve the problem
    Please help me with 1G -FE pin out to march 1JZ FSE computer box
    Apr 23, 2011 | GPS
    Looking for Toyota 1G-FE engine ECU wiring manual
    plz I need Toyota 1G FE ECU Pinout Diagram
    looking-toyota-1g-fe-engine-m0ijwutgr550h2wxmvhyvhap-1-0.jpg thanx
    Jan 24, 2011 | Toyota Camry Cars & Trucks
    Where are the timing marks on a 4ZZ-FE engine?
    Please buy a cheap shop manual. Get this wrong and you will be very sorry.
    May 05, 2009 | 2001 Toyota Corolla
    Miscellaneous Logo
    37 people viewed this question
    Top Miscellaneous Experts
    Andy Fraser
    Andy Fraser
    steve cannon
    Level 1 Expert
    Dan Grod
    Level 1 Expert
    Are you a Miscellaneous Expert? Answer questions, earn points and help others
