Question about Aiwa Audio Players & Recorders
AIWA LX20 tone arm won't go onto record. Does it need new tone arm belt?.
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
marketex
  • 371 Answers
SOURCE: took apart tone arm of a Numark tt200
On this PAGE you will find each and every part of any component of the the TT200 for sale from Numark, including an "S" arm.
Replace, do not fix,. the arm for this HIGH TORQUE lathe.
Posted on May 02, 2009
  • 133 Answers
SOURCE: tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
STYLUSCITY
  • 271 Answers
SOURCE: I have a Denon DP-51F turntable. It was fine the
Hi, it has seized from lack of use. Disassemble and lube it. styluscity@gmail.com
Posted on Sep 13, 2010
  • 86 Answers
SOURCE: ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
Posted on May 22, 2012
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
May 22, 2012 | Audio Players & Recorders
I have an Aiwa PX-E80K turntable. Whenever I start the turntable, the tonearm raises moves across, drops on the outer edge of the vinyl then then turntable stops. The belt is still attached. Anyone able to...
I suspect the belt is that slack that when the arm weight is on the record, the belt slips around the shaft of the motor. Does it start up again when the arm is lifted up? If it does then you need a new belt.
Jan 09, 2011 | Aiwa Audio Players & Recorders
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Sep 19, 2008 | Sony PS-LX250H Turntable
Tone arm won't drop
- OPTiC
www.1200s.com
Aug 24, 2008 | Audio Players & Recorders
Aiwa LX770 Turntable won't start
It's a bit after Jim's post, however I had what appears to have been the same problem with my LX770 after it had been stored in the loft for quite a few years. I found the problem to be caused by the tone arm mechanisms stalling - The band that was associated with lifting the arm had turned to a black gunge and was not allowing the motor to rotate, also the motor associated with moving the arm backwards and forwards was struggling to turn. I cleaned the tone lifting pulleys and replaced with a small elastic band (for a temporary fix). This was a little fiddly as you have to take off a spring and a couple of gears to get the new band in place. I cleaned the runners and cleaned off the grease on the worm gears associated with the arm tracking (as I suspected it may be more viscus than originally installed), lightly oiled the tone arm tracking gears. It still seamed to take an amount of helping the tracking arm gears until they were able to move freely. With the tone arm mechanisms working properly the whole unit now seams to be working.
Top tips if you attempt this: WARNING - If the unit is plugged in, the transformer and high voltage wires are live regardless of whether the on button is on or off on the front of the record deck. PLEASE do not take any of my comments as recommendation you should ever do anything with the unit plugged in! Remove the little stylus carrier before you start taking the player to pieces - saves damaging it! Remove the record mat and aluminium platter before turning the unit upside down. Manually push the tone arm to about 0.5cm from its furthest travel - so you can remove the tone arm mechanism plate. May be a little stiff as the wires have to slide of the pulleys for the tone arm to be pushed. To access the tone arm mechanisms, remove the main bottom plate (and greasy spring), then undo the screws which hold on the rear undertray. With the decks buttons toward you, you should then be able to lift the rear tray slightly and tilt the tray towards you to expose the tone arm mechanisms. You shouldn't need to remove the circuit board with the control buttons on the front of the unit.
After getting it going, I found that I needed a Phono preamp to get the signal strength necessary to use the deck for transferring vinyl to my PC.
Good luck
Oct 20, 2007 | Audio Players & Recorders
118 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
