Lg tromm front loading washing machine has
Lg tromm front loading washing machine has started leaking water from the soap dispenser while the machine is filling. I have been hitting the pause button when the water starts to leak so what's in the dispenser can drain into drum. Is this just a detergent/fabric softener build up problem?
  • prngeorge633 Jul 20, 2009
    Water flows in at a good rate, does not seem any different from the good old days when the thing worked right. Did use some non HE Tide liquid detergent though and have a teenager who most likely used too much.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Tell me what detergent and amount you are using, and how fast the water flows into your machine. (just a trickle, or with good force)
  • 221 Answers
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
I have a front loading washing machine. The soap dispenser is no longer dispensing detergent into the machine
SOMWE TIMES THE TUBE LINES CAN GET BLOCKED OR CLOGGED OR EVEN HAVE LEAKS, YOU WILL HAVE TO TAKE OUT THE DISPENSER AND CHECK CONNECTING TUBES. ALSO TRY POURING VINEGAR INTO TUBE AND LET SIT FOR AN HOUR OR SO
Jan 27, 2016 | LG WM2688HWM TROMM SteamWasher
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
The soap dispenser drawer is leaking water down the side of the machine.
try turning water pressure down a little, also pull drawer out 10 millimeters or 1 centimeter that might help. please reply if u need more help
Mar 22, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Lg tromm wm2277wh washing machine
Is the water valve screens plugged restricting the amount of water going into the washer other wise your pressure switch is reading the wrong water level.
Oct 13, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
771 people viewed this question
Top Washing Machines Experts
