Question about Kitchen Appliances - Others
I am going to raise dough overnight, then I want to transport that,by car, in winter weather for 1 hour then bake on arrival. will that hurt the dough
    Top Expert:
  • Kitchen Appl... Master
  • 77,544 Answers
No will be fine and make a delicious loaf of bread.
Posted on Dec 04, 2016
Handle stays down
Doughpro DP1100 Dough Press - YouTube
? 1:27
www.youtube.com/watch?v=QM44NdPY3DQ
Oct 7, 2010 - Uploaded by ZescoVideos This is a how-to video for Doughpro's DP1100 Pizza DoughPress.
ProLuxe DP1100 PizzaPro Pizza Dough Press, Manual ...
www.missionrs.com/doughpro-dp1100-pizzapro-pizza-dough-press-man...
$3,074.60 - ‎In stock Product Description. Efficiently produce crusts that are equal to hand tossed in no time at all with this ProLuxe (formerly DoughPro) DP1100 PizzaPro Pizza ...
Oct 02, 2015 | DOUGHPRO/PROLUXE Dough-Pro DP-1100 - Pizza...
If program in 6 for dough how long will I have to leave it for and then put in fastbake
typical dough programs run about 1 hour and 20 minutes. This is so the dough can then be baked your outside oven after it has risen. Follow the instructions in your owners manual on how to handle dough after the dough program ends.
Feb 25, 2015 | Russell Hobbs 18036 Breadmaker Fresh Bread...
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Dec 08, 2014 | Kitchen Appliances - Others
How long does it take to dough to rise?
That depends on many different factors.
1. The amount of yeast you added.
2. The amount of salt you added.
3. The heaviness of the dough.
4. The amount of sugar you added.
5. The age of the yeast you used.
6. The type of yeast you use (dry, fresh, fast raising, etc)
7. The temperature you keep the dough (the cooler the longer).
8. The type of flour you use.
9. etc.
Jul 17, 2014 | Baking
Does keeping the air conditioning at 'on' in the car at all times a recommended action
It does not harm the AC but it raises your fuel consumption by certain percentage, it is actually recommended to run the AC even during winter time from time to time otherwise the compressor does not get lubrication from the gas and it can cause damage once on during hot weather.
Dec 21, 2011 | Cars & Trucks
I need a recipe for White Bread
Hi greatdane,
Plz find below the recipe for White Bread:
Ingredients:
  • 6 to 7 cups all-purpose flour
  • 3 tablespoons sugar
  • 1 tablespoon salt
  • 2 tablespoons shortening
  • 2 packages quick acting or active dry yeast
  • 2 1/4 cups scalded milk cooled to about 120°
Preparation: Mix 3 1/2 cups of flour with sugar, salt, shortening and yeast in a large mixing bowl. Add very warm milk; beat for about 1 minute. Stir in enough of the remaining flour, a cup or so at a time, until dough is easy to handle. Turn dough onto a lightly floured surface. Knead, adding more flour as necessary to keep it from sticking, until smooth and elastic, about 8 to 10 minutes. Place dough in a large buttered mixing bowl. Turn dough over so greased side is up. Cover with a clean dish towel and let rise in a warm place, out of drafts, for about 1 hour, or until doubled. When dough is touched, an indentation will remain. Punch dough down and divide into two equal portions. Flatten each half with hands or rolling pins into a rectangle about 18x10 inches. Starting at 10-inch edge, roll dough tightly; pinch long seam together. With sides of hands, press each end of loaf; fold ends under loaf. Place loaves, seam side down, in loaf pans (approximately 9 x 5 x 3-inch). Brush each loaf lightly with butter. Cover loosely with clean dish towels and let rise until double, about 35 to 50 minutes. Preheat oven to 425°. Bake loaves on a low rack, so tops of pans are at the center of the oven. Bake for 25 to 30 minutes. Bread will sound hollow when lightly tapped. Makes 2 loaves of white bread.
Aug 24, 2011 | Breadman TR846 Bread Maker
Using the same recipe I've used many times, the machine stopped after mixing and before rising, and all lights went off, and did not come back on after a half hour. I am going to start over. However, I am...
If the bread maker still works, means that you had a temporary power outage. You can naturally bake it in the oven, but you will have to allow time for the yeast to activate and rise the dough to approximately double size than the starting dough. You can use a cooking pot full of warm (120-135f) and have the dough seating over it (in the pan that you will bake it in).Cover the whole thing (water and dough)with terry cloth towel for minimum of 45 minutes and bake it in a pre-heated oven (425f). Avoid any drafts durring the rising of the dough.
Jan 16, 2011 | Panasonic Kitchen Appliances - Others
The bread did not bake. The ingredients mixed,
You may have a bad heating element. If this is the case it will be hard to find that part.
Oct 18, 2009 | Breadman TR845 Bread Maker
1996 Plymouth Neon stalls on highway during hot weather
Those cars are bad about the cam sensors going bad wouldnt hurt to repalce as good maintenance.
Aug 05, 2009 | 1996 Dodge Neon
Kitchen Appliances - Others Logo
60 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
