Question about Nokia 3110 Cellular Phone
Restarting anytime a memory card is inserted.
Hi. please my phone always restart its self any time i insert a memory card and works properly any time i remove it. (nokia 3110c) .please help me out.fred
Always restarting
Hi Reynaldo,
Please find the below steps to resolve this issue
Step 1: Turn on the mobile
Step 2: After 2 to 3 mins, switch it off
Step 3: Now remove the battery
Step 4: Remove the Memory Card
Step 5: Remove the Sim Card
Step 6: Now hold the Turn on/off button for 10 secs
Step 7: Take the hand from the button and insert the sim and battery to the mobile, please dont insert the Memory Card
Step 8: Now hold the Turn on/off button for 5 secs continuously
Step 9: Take the hand from the Turn on/off button
Step 10: Leave the mobile, for 10 to 15 mins, after that please insert the Memory Card
Step 11: Now check the status of the Mobile
Thanks for contacting Fixya
Regards,
Aysaam
Apr 02, 2011 | Nokia 5530 XpressMusic Smartphone
My 6300 restarts automatically when i insert any memory card why?
hi
there are some phone that will restart when memory card is inserted automatically for first time. but make sure that your phone will support the memory card that u use. if still problem arises kindly try your memory card in other phone if it works properly means the fault is in your mobile. kindly format the phone and try it. this will fix your problem..
thank you
Dec 19, 2010 | Nokia 6300 Cellular Phone
Hi my mobile Nokia 3110C its working fine without memory card. Its often restarts when insert memory card.. I tried that memory card inserted into another mobile that mobile working fine with that memory...
The problem are in MMC IC that not in good condition.to fix the problem only with change this IC.If you do not the expert I suggest to take to the Nokia service center because it need a service tools like a blower to replace the IC.
Jun 13, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c always restart when my memory is inserted.. how can i solve this problem? but if i didnt insert my memory my phone doesnt restart..
It is obvious that the memory card you inserted into your phone is bad (it has virus) and that's why the phone keeps restarting.
Try inserting another memory card and let's see what happens.
Take care.
Nov 20, 2009 | Cell Phones
I am having problem with my handset it is turning off automatickly. And some times it showing missing battery
first remove the memory card.
then restore the setting
then format the card using pc
restart the phone.......
again restart
insert memorycard
it'll work
if helpful m always here.......
Oct 23, 2009 | Samsung SGH-D900 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 classic Have the problem of restrart automatically?
its not a problem when insert a new memory card you need to restart the phone for it work fine. or this is what you should do, whenever you want to change memory card on your phone turn it off and insert the card the turn the phone on again. its a simplication. i think this solution will help you if apply it. thanks
Jul 02, 2009 | Nokia 3110 Cellular Phone
Memory card not detected
Have you inserted your memory card properly?. If you have inserted it properly , then just restart your mobile
Nov 28, 2008 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Can't see a thing on screen
hi sir
please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
if doesn.t work mite memory card may be corrupted..
Sep 01, 2008 | Nokia N95 Cellular Phone
My k750 restarts when i insert a memory card
plzz.. chect ur card properly...it is ok or not..then insert onother card in it...
Aug 03, 2008 | Sony Ericsson K800i Cellular Phone
Nokia 3110 Cellular Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
