I hooked my pre amp to the VCR DVD port on a sir TX 576 and l do not get music out of the left main speaker ?
  • 261 Answers
SOURCE: No sounds from rear speakers..... Yamaha HTR-5650
Select different modes on the remote or front panel and make sure all speaker that you have hooked up are showing on display. Are the Lt & Rt channels at least playing audio? If you want, i can step you thur some steps to try in live chat if you want today. Let me know as i have experience in this area! Sincerely Guru Jay
Posted on Feb 02, 2008
  • 341 Answers
SOURCE: Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Posted on Sep 25, 2008
  • 67 Answers
SOURCE: Speaker set up problem
They hook to the rear surround.
Posted on Dec 20, 2008
  • 4234 Answers
SOURCE: Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Posted on Feb 25, 2009
  • 113 Answers
SOURCE: connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Posted on Aug 28, 2009
I added a turntable to a onkyo sir TX 576 using a preamp to power it lean the preamp into VCR DVD in and in only getting. Music out of main speaker right and none out of main speaker left?
Hi Dave, please make sure that the RCA plugs are all the way in. Try flipping them, red to white and white to red. See if the audio moves to the other speaker. If it does the receiver and speakers are ok. Try a different analog input. Thank you, Onkyo USA
Dec 04, 2016 | Onkyo Audio Players & Recorders
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
I'm trying to hook up a Carver HR-752 to Bose 901's series VI, I would like to use the preamp out and in on the back, do I need a seperate amp to use these? I have them going through the Tape
To setup the Bose 901's so that all of your connected equipment's sound (cable/dvd/games/stereo/etc) comes out of the 901's.
If you already have a receiver with front left and right pre-outs, I would add an amplifier. (other option is a pre-amp) Use the amplifier to create the loop the 901's need w/ their EQ and it will also add a cleaner sound and added power. That's how you can really make the Bose 901's sound amazing.
Feb 01, 2013 | Bose 901 VI Main / Stereo Speaker
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
Guru, Premium Expert @
Jun 28, 2010 | Onkyo TX-SR606 Receiver
I have an Onkyo TX-SR507. I just hooked it up
Hello Katieandjona,
My first & second
guesses would be monitor & head-set modes...
(possibly Zone 2 activated)
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/ STANDBY] button (see page 93).
Manual... page 5
Hope this helps
Aug 26, 2017 | Onkyo Tx-sr507 A/V Receiver
Connect an amp to a Onkyo tx-904
Aug 28, 2009 | Onkyo TX-SR705 Receiver
More watts needed
Add another power amp to line outs from your main amp to your speakers this will give more power(current) to your main speakers as you have decreased load on main amp
Dec 22, 2008 | Onkyo TX-SR601 Receiver
What cords do you need to hook up the panisonic DMR-E75V DVD/ VCR Combo?
hook to a what? direct to your TV or to an audio/video amp? That depends on what is available in your DVD/VCR or toy our TV. simple cnnection is just the composite video signal colored yellow RCA connector. Video out of your DVD/VCD to Video input of your TV. Another option maybe if it has which is better is S-Video output of DVD to S-Video input TV. if you;re doing it via audio/video amp, then simply look for the input source and connect your video there. The audio... it's also RCD connectors colored Red/White for your right/left channels. it will always be like that for a stereo amp setup. but if you are using amp with sound preocessing then you'll have more audio connections at least 5, mains left/right, surround channels left/right, your center speaker, your subwoofer.
Apr 06, 2008 | Televison & Video
If you have a VCR it is easy. Just plug RCA cables into audio out right and audio out left (on VCR) and other ends into VCR audio in right and left at rear of your receiver. If there are two sets of video audio inputs, push button on front of receiver to agree with where you plugged cables in. (ie. Video 1 and video 2)
Dec 18, 2007 | Onkyo TX-8511 Receiver
Zone 2
if you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Nov 11, 2007 | Onkyo TX-NR801 Receiver
