Question about Kenmore Dryers
I have a kenmore elite dryer and I have a light in the drum but I seem to power going to the control panel,nothing lights up there
SOURCE: My dryer seems to be partially working.
Posted on Oct 23, 2007
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at Order on line and have the part shipped directly to you. access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
  • 1226 Answers
SOURCE: Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Posted on Feb 06, 2008
  • 1028 Answers
SOURCE: Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd sure there is 220 volts to rear connection first
Posted on Aug 04, 2008
  • 25 Answers
SOURCE: Kenmore HE4 dryer (gas)...Drum light is on, so the
oh its nothing press those two buttons and bam your problem is sloved for the control panel
Posted on Apr 08, 2010
Kenmore elite HE3 drum light always on, wont run
Ohm out the door switch if the light won't go out electronic control thinks the door is open.
Mar 31, 2014 | Dryers
My dryer is dead. I have ohmed out the cord and changed the dryer control board (8546219). Still dead, nothing at all. Any other ideas? I have checked the fuse and it is good. I had a local repair man look...
hello again,
no thier doesn't seem to big issue with with reconditioned control panels in fact i dare say yours is good since the dryer didnt start with the original one and still wont start with the one you have replaced. having checked teh thermal fuse to be good and with basically 2 control boards yet the dryer doesnt run it seems very possible the motor is going to be the problem...not sure what led ya to the control board yet it the drum doesnt turn the very part that turns it when power is applied to,if it has powewr to it and doesnt turn the drum it would seem to me its bad....dont get me wrong on this but its like having a broken leg and going to the doctor and saying i believe that my heart is weak since my legs hurts and totally disregarding the broken leg
Oct 04, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
I have no power on the control panel but the light works inside the dryer
I have power to the dryer. when depressing the selector switch, 20 min for example, the ride light illuminates, you hear a click sound but nothing happens
Aug 19, 2009 | Kenmore Elite HE4 Electric Dryer
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
