Lid on wtw800 won't open all the way - Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
2007 sky saturn trunk latch on driver side won't open
A Saturn Sky is a 2 seater and has no rear fold down seats and no key to open the trunk lid.
Jul 29, 2012 | 2007 Saturn Sky
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Can i use my washing machine with no lid switch
as long as everything is working it's ok,all it is is a safety switch so the washer won't run with the lid open,a kid could open the lid when it's spinning and it won't shut down and if the kid sticks his or her hand or arm inside it could get ugly so it's a safety switch that's it.
Feb 22, 2012 | Kenmore Washing Machines
Dishwasher soap cup lid won't open
If you can't find anything to pry it open with,just call the manufacturer or store.
Feb 18, 2012 | GE Dishwashers
Washer wont cycle
Number 11 is your lid switch. It is very easy to repair. To test it watch the video.
Older models would wash with the lid open but not spin. This later model washer won't wash or spin with the lid open so I suspect you have a broken lid switch. IF that turns out not to be the case then I would next check the motor start capacitor. When these fail the motor won't work at all.
On your machine you gotta have a long skinny screwdriver . On the back side of the washer you back out a screw on each side and then she pops up.
I gotta whole page of stuff on these washers HERE
Nov 01, 2011 | Estate TAWS850PQ
My washer has been stopping mid-cycle like the lid was opened lately. I have been able to open and close the lid to "jar" it into finishing the cycle(rinsing) until now. It has just stopped and...
The lid switch will need a slight adjustment to properly activate, or you could bend the raised bump on the back of the lid out a bit so it activates the switch better.
Jul 27, 2011 | Maytag Washing Machines
Popped the lid open to change vacuum cleaner lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
