Question about Cell Phones
When i try to link my phone on my ouku radio via bluetooth the radio says the blue tooth function is not open
  • 316 Answers
SOURCE: motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Posted on Nov 03, 2007
  • 103 Answers
SOURCE: h375 bluetooth
Your default passcode is 1234 or 0000 so try this and tell me if it works.
please rate me. thank you.
Posted on May 30, 2008
Bajanguru
  • 7752 Answers
SOURCE: D900 Bluetooth
try a hard reset *2767*3855# then try again
Posted on Jul 04, 2008
  • 3 Answers
SOURCE: unable to activate the bluetooth in samsungX820 ceel phone
hi i am abid pls solution me hand set mobile samsung x820 bluetooth. my email abid3322@yahoo.com
Posted on Apr 03, 2009
SOURCE: LG VU does not recognize my blue tooth while trying to pair two
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
Posted on May 11, 2009
What does it mean by available devices when you turn blue tooth on on your phone
you can sometimes set the other bluetooth devices to be discover able . If you don't the phone won't see the devices via bluetooth .
Sometimes when you put a device in pairing mode it is making its self discoverable other times you have to set it to be discoverable and then put it in pairing mode.
Bluetooth is a low power radio system that connects devices together.
Say you had taken a photo on your phone well with a computer paired to your phone via bluetooth you can share the file via blue tooth to the computer via the radio link blue tooth system.
If you had a bluetooth hands free system in your car you could pair it with you phone and use it with the phone .
Mar 07, 2018 | Cell Phones
How do i set up blue tooth
You will need the owners manual for it, Everry manufactur is different in the way you have to set it up. Ihate to tell you.
Nov 06, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
Ouku
will not read any USB connection
Sep 05, 2012 | Crown Ouku 7" Touch Screen Dvd In Car...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
Hi everyone. i just bought samsung link cell but i dunno how to use the bluetooth here. can you help me with this? actually, i tried to but the only command here is copy/move but it only copied/moved to...
before purchasing the phone did you ask if the phone has a blue tooth?.Because from the description you said your phone only send via multimedia message or text.
For a phone to have a blue tooth, in the send options blue tooth phone has three option which are multimedia message, text and blue tooth.
This is just an advice, if from where you bought the phone from they told you it was a blue tooth phone, you can still go back and make complains of the phone and tell them it is not a blue tooth enabled phone.
Have a nice day.
Mar 15, 2010 | Cell Phones
How to pair my phone with the bluetooth on a panasonic cq-rx300n
has the radio got blue tooth installed , as some say "blue tooth ready" on box but need an additional piece of kit to get it to work, ..........if it has then you need to find the BT function on the radio, either menu/ sorurce button and search with your phone , make sure phone is "visible" in the blue tooth mode
Jan 02, 2010 | Car Audio & Video
HELP PLZ
have you tried turning blue tooth off then back on a again
Sep 03, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
