Question about Coffee Makers & Espresso Machines
I've been away and the coffee machine ESAM4500 has been idle for three months. After filling the water tank the machine does not recognize this and displays "Fill Tank" and will not proceed further
mirran
  • 515 Answers
SOURCE: Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Posted on Aug 23, 2008
mirran
  • 515 Answers
SOURCE: "Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Posted on Oct 26, 2008
SOURCE: The Sensor Magnet for water tank does not float to the top
OK, first of all, I do not recommend my solution if you are forgetful or do not check your water level manually daily.
However, I found a super easy solution.
The way the unit works is to use a float in the water chamber with a magnet on the bottom. When their is enough water in the tank, the float rises and the magnet on the bottom floats to the top of the magnet chamber. When it floats up, it aligns with a sensor in the machine that allows the machine to operate. When the the water level lowers, so does the magnet and drops below the internal sensor disabling the machine with a "Fill Water Tank" error message.
To eliminate this error and allow the machine to operate, I simply popped off the lid to the magnet chamber with a butter knife and turned the water chamber up side down to let the magnet float fall out. Remember to empty the water first.
Here comes the highly technical part. Turn the magnet float upside down and slide it back into the float chamber. Since the actual magnet is on the bottom of the float it now is at the top allowing the internal sensor to turn off. No more error message!
The reason I do recommend this is because this completely defeats the purpose of the sensor and will most likely damage your machine if you run it without water. Keep you tank filled however and you will eliminate the frustration of a "float gone bad" keeping you from your morning caffeine.
Posted on Jun 13, 2009
espressonist
  • 1711 Answers
SOURCE: CAN NOT MAKE A COFFEE DO NOT UNDERSRTAND THE MESSAGE I GET.
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Posted on Jul 17, 2010
  • 1089 Answers
SOURCE: Our Comfort machine won't brew and constantly
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Posted on Sep 23, 2010
Descaling?
Depends on the type of coffee machine, but with a normal pour and drip machine, you swing the water nozzle away from the filter cup so that the water goes back to the reservoir where you pour the water in. Mix CLR to the recommended strength and run the coffee machine for about 20 minutes recycling the water the descale solution. Then carefully swing the nozzle back over the filter holder. Run three normal cycles with fresh water and that's it.
For fixed and plumbed in coffee makers, there is a tank that you fill with descaler and a lever that cuts off incoming water and takes it from the tank. You would need to refer to the maker's instructions.
On a free flow machine, you can just make enough solution to fill the tank and run it. Then rinse with fresh three times.
Oct 12, 2016 | Coffee Makers & Espresso Machines
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Water won't flow thru to filter or pot. Don't know the exact model but it is a 12 cup self cleaning.
Self-cleaning is wishful thinking. Every three months or so, run a pint of vinegar through it, as if making coffee (no coffee!) then flush with two tanks of water.
Mar 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Coffee just drips out of machine, have left off over nite, worked fine now just drips & we get only about a 1/4 cup. Have not desaged as is only about 6 months old?? Bob Spackman
wer
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig Platinum B70 Coffee Maker
Will not brew or heat water even after filling resoviour
Sorry to read about your problem, I hope this helps you out.
try a re-seat the fill tank.. if unit is old try this or if new contact Keurig.com
Dec 25, 2010 | Keurig B60 Coffee Maker
I have the platinum Series Quiet Brewer (cinnamon color) that I bought 3-11-10 on QVC. About 1 months ago it started shuting off after filling one cup of coffee, it fills the same amount of coffee no...
sdfdf
sfsd
fsdf
ds
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
Does not brew coffee consistencty, water does not always flow from res tank...even if water flows down from tank the machine will make the heat noise show brew ready and when u push the button it either...
Dec 22, 2010 | Keurig B60 Coffee Maker
My b60 machine sometimes doesn't fill all the way, i notice when it goes threw its cycle, the auto fill which isn't hooked up will fill the holding tank.
Dec 16, 2010 | Keurig B60 Coffee Maker
The machine will say Fill water tank. So, we will take the container out of the machine fill it to or just a little above the recommended line and then put it back into the machine. It will be full and it...
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Nov 16, 2010 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
