Question about Dishwashers
My elite dishwasher will not start and has a service code of F4E1. what does this mean?
2 Suggested Answers
  • 15478 Answers
SOURCE: dishwasher f4e1
This is an error that means the controller is not talking to the motor. You need to check the connections on the motor
Posted on Feb 09, 2014
Kenmore elite dishwasher model # 630.12913314 is displaying code E24. what does this code mean?
That code means no drain flow. It could be food debris blocking the pump or the hose
Feb 22, 2017 | Kenmore Dishwashers
What does code F2E2 mean on the display
My Kenmore Elite dishwasher is showing code F2E2..What ...
www.shopyourway.com > Agafia Reutov > Questions
The F2E2 error can be frustrating. The problem is the User Interface is not communicating with the main control board. This error is mainly caused by a poor ...
Kenmore elite service code f2e2 ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Te hose came off the bottom of the washer, then I got the service code f2e2. ... I have a kenmore elite dishwasher model 665.1396 ERROR CODE F2E2 ?
Oct 22, 2015 | Dishwashers
F4e1 error
You can try resetting unit by disconnecting it from the outlet or by switching off the designated circuit breaker for 2 or 3 minutes, then restore power. If the reset doesn't work, I think you need to call a technician to properly diagnose
Jun 21, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore dishwasher not working code f4e1 came on
I checked the searspartsdirect.com website, and according to them, it is a 'motor communication issue.' In order to get more details, you have to create a login, and it was taking forever to complete that, so I gave up.
Try flipping the circuit breaker, leave it off for 1 minute, then turn it on again. Do you still get the error code?
Okay, I finally completed the sign-up process. Here is some more info from an actual repair technician:
The F4E1 is a code that signifies a WASH MOTOR
issue. Specifically, no Communication. This is usually caused by: A loose connection in Wash Motor Circuit, Motor Communication Circuit and/or an open wash motor. 1. Unplug dishwasher or disconnect power. 2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit with meter. Fix/replace an open connection/part. Motor fuse on control open. 1. Start Service Diagnostics Cycle using keypad and advance through the error code intervals to interval 19. ( shown on image below ) 2. Listen for 2 relay contact clicks at the start of interval 19 (to confirm both the pilot and motor relays are turning on.
NOTE : These relays provide power to the motor, but the motor does not start until it receives a start command later in the cycle). If hear only 1 or zero clicks and wash motor does not come on later in service cycle, and there were no loose wire communication wire connection when checked above, then unplug dishwasher or disconnect power and replace control.
Faulty wash motor. 1. Unplug dishwasher or disconnect power. 2. Use inspection mirror to inspect for water leakage and/or overheating on the wash motor. If evidence of overheating exists, replace wash motor. If evidence of moisture exists, check seals and hoses.f you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Jun 11, 2014 | Kenmore 665
Dishwasher code F4E1
The F4E1 is a code that signifies a WASH MOTOR issue. Specifically, no Communication. This is usually caused by:
2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit. Fix/replace an open connection/part. Motor fuse on control open.
Using keypad press "Heated Dry", "Normal Wash", Heated Dry", Normal Wash, and the "cancel button" to reset.
Start a cycle and listen for 2 relay contact clicks at the start of interval to confirm both the pilot and motor relays are turning on.
Apr 21, 2014 | Dishwashers
Error code F4E1 need reset
Turn off the power to the dishwasher for about 5 minutes before you power it up check that the water supply line is on. Also check for restricted drain area. Power it up and clear the power fail fault see if it works
Feb 24, 2014 | Kenmore 24" Built-In Dishwasher, Stainless...
Dishwasher f4e1
Feb 09, 2014 | Kenmore 665
CODE F4E1 will not go away
This error means that the controller cannot communicate with the motor. It is possible that something came loose when you replaced the clamp. Recheck all the connections .
Feb 09, 2014 | Kenmore 15322 / 15324 / 15329 Built-in...
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
