Question about Retail Supplies
I have a Casio SE-S900 and I need to change values for price keys. How do I do it? Following steps in the user manual gets me no where. Perhaps, I am looking in the wrong place. HELP ME, PLEASE!
  • 1294 Answers
SOURCE: RE: MAT12PDBAQ Maytag top-load washer (Commercial/Coin-op)
Click on 'washing machines' (below FIXYA) on this website, & search for your brand. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 10, 2008
SOURCE: Need user manual for Casio sl-200te
To change the tax rate, first press AC. Then press SET % for 2 seconds. Next, press TAX+, then enter the new or current tax rate. Enter the rate for a single digit tax rate such as 5% as 5, a single number; if you have a fractional percentage rate, such as 5.75%, enter it just that way: the 5, then a decimal and followed by 7& 5. Then press SET % again and you're done! I just did it on two of the calculators and it works. Hope this helps!
Posted on Jan 28, 2009
SOURCE: CASIO DR250TM CALCULATOR
In case you haven't found the solution yet. This is it.
Move buttons to "Print" and "F"
Press CA key
Press % (set Key)
Press "time"
Press and hold down the % (set key) until the numbers come back and start flashing.
Put in the correct numbers.
Press % (set key) again and your done.
Hope this helps.
Linda
Posted on Feb 11, 2009
  • 7993 Answers
SOURCE: I have a casio fx9750GA plus and need to know how ...
The following uses keystrokes and screen captures from the FX-9750GII but the essential information is the same. Use the F6 key to move to next page of TABS (those at the bottom of screen) until you find the TAB that interests you (PROB, RAND#, INT, etc.)
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates key presses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
Posted on Jul 25, 2010
SOURCE: I am looking for a user manual for casio AMW-705 - 4735
Here you go
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4735&submit.x=28&submit.y=8
If you would like to find manual for any other model you need this link
http://world.casio.com/wat/download/en/manual/
Posted on Jul 28, 2010
HOW DOU YOU CHANGE A PRICE ON A CASIO SE-52000 CASH REGISTER
Try this link. The product is discontinued but you may be able to follow some of the links there to solve your problem.https://www.elepos.com/products/Casio-SE%252dS2000-Electronic-Cash-Register.html
Oct 12, 2014 | Computers & Internet
I have a casio Se s900 cash register. It currently shows the subtotal in the customer display in large type with the total being in small type. Is it possible to change how this displays?
Yes . turn your key to P and scroll down to program and enter press 1 or 2 an press subtotal and select settings , then scroll to display and choose font then selct the font you want
Jul 28, 2014 | Retail Supplies
How do i programme prices on the casio SE-S300 till?
Turn key to Program 1 SUBTOTAL price (no decimal point) Item button SUBTOTAL
The Se-S300 manual can be found here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jan 08, 2011 | Casio Parts Cash Register PC Desktop
I cannot change the price for an item on CASIO TE-2400 register
Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
Mark
Nov 16, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
67 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
