Question about LG Dishwashers
My lg dish washer leaves the dishes dirty and the soap is still in washer
    Sergeant:
  • LG Expert
  • 448 Answers
Check water hook up and its hooked up to hot water line or washer is not draining if water still there spray arms may be plugged up
need more info model # help
Posted on Dec 22, 2016
  • 213 Answers
SOURCE: dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Posted on Nov 21, 2007
  • 21 Answers
SOURCE: ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
Posted on Jun 10, 2008
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 81 Answers
SOURCE: Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Posted on Apr 24, 2009
When washer is discharging its water it comes out the air vent, the inside of washer is dirty. What can I do to fix the problem. Thank you ...
You need to take back of dish washer off unhook the drain hose and clean that hose good with soap and water or companies recommandations for cleaning hose and as for inside being dirty use a disinfectant clean the inside out and then after hoses are put back on and back is back on run dishwasher with no dishes and no soap for one cicle to rinse and test unit.
Oct 09, 2010 | Kenmore Dishwashers
LG model LDS5811WW/02 has never cleaned the dishes since first installation. Put clean dishes in and they will come out dirty too! Have tried all dishwasher soap types and brands and drying agents. Always...
if the soap/detergent isn't completely rinsing out of dispenser, it sounds like water isn't directed the top spray-arm. possible a defective vario motor; as it directs water to the water channel that supplies water to the middle and upper spray arms.
Jul 03, 2010 | LG LDF8812 Stainless Steel Built-in...
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Husband mis filled ge profile washer dispeser. can we use mixed solution or should we throw it out
Did he overfill the soap dispenser with extra automatic dishwasher soap or with something else? If it is just automatic dishwashing soap then maybe run the cycle with no dishes in it on heavy wash. Now if he filled it with regular dishwashing soap clean out as much of it as you can then run the washer without dishes. If you leave regular soap in there your kitchen will be filled with bubbles.
Sep 13, 2009 | Washing Machines
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dish Soap does not open during cycle leaving dished dirty.
I had this happen a couple of times because the rack was not in all the way and blocked the door from opening.
Jul 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Ge quiet power 3 troubleshooting
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
LG front loader not filling properly
You have to remove the top of machine to have access here. Plug off the wall; you need a grip plier to loosen the clip to see what is blocking the hose.................refit carefully & firmly.
Nov 03, 2007 | Kenmore 44102 Front Load Washer
Dishwashers Logo
52 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
