My machine is acting up on and off, one time my technician touched and held a button on my 880 to reset it,cant remember what that button was can you help me, it was really helpful the last time
  • 1913 Answers
SOURCE: Toshiba sat. laptop- changed bios password/ cant remember it
u have to open back side of lap top then u see cmos cell out away your cmos batery cell fore 15 minutes then reattch it.then give power up. then iot reset .
Posted on Nov 18, 2008
  • 50 Answers
SOURCE: Elna 7000 - Mislaid manual. How do i use program B (letters)?
Hi jennymalibu! The best thing for you to do would be to download a new manual (free) from the Elnal site. It's in a .pdf format, so you need to have Adobe Acrobat Reader installed on your computer (also free at Below is a link to your manual. Just click on it, or if it doesn't work, copy and paste it into your browser window. Good Luck! Hope this helps! Hal
Posted on Jun 10, 2009
SOURCE: To reset the computer on a 89 reatta, you push 2
Put it the Climate mode, and hold the off button and the fan up at the same time. I think this is what you want.
Posted on Jan 11, 2010
SOURCE: Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Posted on Jan 12, 2010
  • 1851 Answers
SOURCE: my nuvi 205 touch screen is acting up
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
Bernina 880 will not respond to touch screen
Recalibrate touch screeen:
Access is achieved by simultaneously pressing the needle position buttons < > and at the same time switching the machine on.
• Brightness is adjusted by turning the stitch length knob.
• Touch the cross symbols on the touch-screen for calibration.
Jan 01, 2017 | Bernina Sewing Machines
What is error code 3502
The fusing unit is causing the error. that part that gets hot. The code is stating its getting to hot. When was the last time a Preventive maintenance was done every 250,000 copies certain parts are to be replaced. You can try reset power off (Main Power Sw is inside) Sub power is on the op panel try leaving the sub on then power on with main close door once on keep the utility button down) the machine hold the utility /counter button down power on the machine wait to you see trouble reset. touch it see OK then power off wait ten seconds power on. IF the code comes back do not reset again the machine is telling you its broke this section of the machine can get hot enough to burn!!!!!! Get a technician out to fix it and conduct a PM remember every 250K and replace drum 500K
Jun 30, 2014 | Konica Minolta Bizhub 600 750 Image...
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Apr 17, 2014 | Tablets & eReaders
Cant reset tablet
Press and hold the vol - at the same time press the power on button
Apr 02, 2014 | Tablets & eReaders
How to reset fuser unit for konica minolta bizhub 420
In Tech mode :
System 1
Counter data fixing unit
Start button
Power cycle the copier
Jun 22, 2011 | Konica Minolta Office Equipment & Supplies
On my prs-600 I press the forward arrow button once to go to next page but pages start scrolling by rapidly as if button was being held down it won't stop until I toggle power slide.
maybe?: My touch was acting oddly. Page-turning was erratic (almost like a sticky key). Sometimes nothing would happen, other times near normal, but often flipped through large number of pages & was unstoppable. Cleaning button area (under / around / in-between) did not help. As I was about to smash the infernal thing to bits it dawned on me... try a reset (see manual under troubleshooting, p 151-152 approx. Has been fine ever since (couple of months daily use).
Sep 20, 2010 | Sony Reader Touch PRS-600
Photocopier error on Rioch Alicio 3045 model showing a code error of SC545
fuser over heat.U need to take the thermistors out one or two cant remember clean all the hard toner of them.when u put them back in make sure they touch the hot roller firmly.Then touch reset button (yellow rectangle) 1 0 7 then hold cancel button (red) untill screen changes 5/6 sec. turn off then on,should work if not then thermostat possibly blown or fuser laps gone.
Mar 29, 2010 | Office Equipment & Supplies
L cant rest my copier D125if
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Aug 27, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Jul 04, 2009 | Dishwashers
