Question about Dryers
Hi we have a BEKO DWD4310W Dishwasher and it seems to be overheating (melting plastic items that have always been fine before) and always running a hot cycle. Might it be the thermostat?
    Top Expert:
  • Dryers Master
  • 40,304 Answers
The high limit sensor may have failed, allowing the dryer to run wild. This condition MUST be corrected to prevent a fire. If you look at the rear of the dryer you will likely see a scorched area surrounding the sensor.
Posted on Dec 05, 2016
Is my beko dwd4310w Dishwasher loosing power part way through it's cycle?
Dont use it. It can prowoke a short circut . Its a problem of electricity you have to open and chack if all wires are all right. If u cant i advice you to appeal to the expert
Apr 04, 2016 | Washing Machines
Overheating dishwasher samsung
What do you mean "overheating"? Are you getting an error code that indicates it's overheating, or are all of your plastic dishes inside the dishwasher melting? If that's the case, then you have a bad controller, one in which the heater relay is stuck on, and you will have to replace the electronic controller.
Mar 07, 2015 | Samsung Dishwashers
DW1644 Beko integrated dishwasher fault. The machine doesn't clean very well, dried bits (like sand) on dishes and glassware cloudy. It's got sufficient salt, rinse aid etc. The filter is clean. I've...
I have same problem with mine (not BEKO) what I have discovered is, it seem to be where the water hasn't run off properly before drying, so I make sure I don't put anything in flat where water can collect. It's not always possible to put things in that are not flat, but try that
Dec 14, 2014 | Beko Dishwashers
Beko DW450 not engaging into cycle on any programme
Not sure, this link may help. Ask Question Get an Answer ASAP
type in the name of your appliance.
Feb 26, 2014 | Beko Dishwashers
Beko DWD5410 - noise
The strange noises are of of your hose water. I think your water system is not alright or unit called ciop is damaged.
Mar 27, 2010 | Beko 24 in. D3421F Free-standing...
BEKO DWD4310W Will not empty
yes it will be the main pcb that is at fault they normally lose a neutral to the pump when they go down
Jun 27, 2009 | Beko 24 in. D3731F Free-standing...
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Beko washing machine fills with water when not in use!!
hi got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
Jun 28, 2006 | Beko 24 in. D3731F Free-standing...
Dryers Logo
50 people viewed this question
Top Dryers Experts
