Question about Miscellaneous
1 blade appears to rotate slower than the other 3, so when i try to takeoff and hover it just flips out. Is this defective or a setting issue?
    Master:
  • 234 Answers
Presuming you are referring to a remote controlled helicopter I have seen many hit something or crash and the set screw for the blade to the shaft has come loose or left the building. If so the repair is frustrating but achievable with diligence and a bit of determination.
Posted on Dec 04, 2016
Why printer squeaks
There are several moving parts inside the printer. more in a color laser printer.
Generally if you have used a refilled toner recently (any color or black), the chances are that the wiper blade in NOT seated properly inside the toner or reversed.
Try the following steps.
1. Set known set of good toner (even if nesrly empty)
2. Perform self test
3. Replace one old toner with new set corresponding color and eliminate which toner causes the squeak..
4. Mark that toner defective and Return.
5. If that is not feasible, try to forcefully rotate the drum in the opposite direction to see if helps flip the rubber blade in place
6. I will not suggest you to open the toner as it can damage the drum, spill toner and lead to you bigger mess.
7. If it is not due to toner, then the culprit is in the several gear trains inside the printer and that can be tricky to solve.
Sep 06, 2016 | HP Color LaserJet Pro 200 M276nw
Lawnmower blades going round but not cutting
It could be two reasons
1: the blade is not sharp enough to cut
2: the bade is set higher than the grass
Mar 17, 2016 | Garden
How do i replace blades on a u816a udi r/c
Just pull the blade you want to replace gently with your hand , you may need a protecting glove, and then push the new one in place.
Dec 26, 2014 | FocalPrice Udi U816A 2.4 GHz 4 Channel RC...
Flip the screen
Flipping the screen is part of the Display in the Control Panel. You have to go to the Settings tab then click Advanced and look for Rotation.
Click Start/Control Panel or Start/Settings/Control Panel then look for Display or Appearance and Personalization. Open the Display then click Settings/Advanced/Rotation.
Jun 08, 2012 | Computers & Internet
Dewalt compound miter rotating slow
Check the brushes first, then the drive belt if it has one.
Oct 17, 2017 | Measuring Tools & Sensors
My login screen has turn upside down
Is it only your login screen? or is it the entire operating system? Does it fix after you log in?
Press [Ctrl > Alt > Up arrow] (all at the same time) to revert back to normal orientation. If it is only the login screen, then it may be a issue with the Operating System.
Aug 28, 2011 | Advent Netbook
I own a craftsman LT 2000 17 HP it has worked well and as a rule I am pleased however recently I changed my blades and encountered a problem in that the laft bade turns slower than the right the result is...
Hi and welcome to FixYa, I am Kelly.
You assessment of the problem is pretty much on the mark. Here is what you should do to check the bearing.
1. Remove the belt from the suspect deck pulley
2. Reach under and try and teeter the blade by gripping the end of the blade and lifting it up and down. (None allowed but compare it to the good blade) Watch both the under side of the mower deck for movement and the upper side pulley of the mower deck for movement.
3. Spin the blade by hand and feel the blade bearing upper housing as it spins You should NOT feel any rumbles, strange vibration or odd noises as the blade is rotated.
4. Wrap a nylon rope around the drive pulley like a starter recoil tightly, tie it off and try and rotate the blade. Reverse your nylon rope wrapping direction and do this again. If the blade moved and the pulley does not move most likely the shaft key in the blade adapter has sheared or is missing. (You can try this test with the belt on....also vs using a rope. I find that I still have to tie the belt together to keep is from rotating.)
By doing this you are going to identify the problem.
Thanks for choosing FixYa,
Kelly
Apr 13, 2011 | Craftsman Garden
Need to adjust Miter gauge for Delta tablesaw 36-977. The 90 degree stop is off
1) Before setting the Miter gauge, check that the blade is straight (parallel) with the slide grooves. Lock a board in the miter gauge and place against the front of the blade, and then the back of the blade. Is the distance EXACTLY the same (it won't matter if the miter gauge isn't straight and square). If not, you'll need to loosen the table and rotate the blade holder to square it up.
2) Now Cut a board in half the flip one side over and place the cut back together. If it isn't straight, the resulting board will have a "dog-leg".
3) Adjust the miter-set-screw until the cuts on the trial board yield a board that comes out straight (or use a Framing square to check).
Dec 31, 2009 | Delta 36 977 Left Tilt Contractors Saw
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
