Question about Samsung Televison & Video
My Samsung 40" lcd has backlight out, replaced the backlight inverter board, did not work. does tcon board need replaced.
  • 822 Answers
Yes
cheers
Posted on Dec 04, 2016
Samsung lcd tv backlight turns off
Check and replace the CCFL lamp/s. Some of them; or all of them might be weak. http://electronicshelponline.blogspot.com/
Sep 04, 2016 | Samsung Televison & Video
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
Jul 04, 2016 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
I replaced the backlight inverter board on my Samsung smart tv and the screen is still black, what could be causing this?
Could be the back lights themselves or the Tcon control board it could even be a faulty LCD , one test for lcd is to shine a powerful light onto corner of screen see if you see any image or raster on the screen . if you get an image most likely back lights need replacing quite a difficult job for the inexperienced . if not most likely t con board .
Jul 03, 2015 | Samsung Televison & Video
Tcon issue?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 01, 2015 | Sony Televison & Video
Need solution for Samsung 39EH5003, Has sound but no picture
if the inverter board for backlight get to work so the cause either your lcd panel get malfunction or the t- con board doesn't work.
Jun 15, 2014 | Samsung Televison & Video
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My digistar tv their is sound but no picture...
Ur LCD inverter board is dead.This LCD inverter board help the LCD screen to have the backlight to have light to the LCD screen and get a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement to get ur LCD backlight back to get a picture.This board is a long board in shape.
Apr 28, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How do you replace the lcd inverter in a Samsung
Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD backlight inverter.Take all the screws the backcover out with a Philip screw driwer.The board is a long board shape,very easy to replaced just unsrews and disconnect wires.Do the reverse to install.
Mar 02, 2010 | Samsung LN-R408D 40 in. LCD HDTV
LN-T4061F turns on black screen sound is there and no menu appears
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backklight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Feb 27, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
