Question about Kitchen Appliances - Others
I have filled the breadmaker When I pressed the start button all that happens is a clicking sound
SOURCE: maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Posted on Sep 11, 2007
  • 1294 Answers
SOURCE: W 6221 stop working
Suggestion: Plug off the wall; open up behind. Take a good look to see if all the electrical connections are fitted well into their respective places, and that nothing has come loose. The fit should be tight, or it will just come off when the machine vibrates...
Posted on Nov 26, 2007
cbinny1
  • 64 Answers
SOURCE: whirlpool washer
First you need to unplug the washer and then remove the front cover below the loading door... (Should be 3 Phillips screws on the very bottom). You will want to run the diagnostic program that is found in the manual which is also located behind that front bottom cover…if you can get it to run that program….. I also had to replace the CCU (Central Control Unit) and the Filter….due to the fact that I was getting a F11 & a F14 error… If you are hearing a faint clicking sound coming from the top back (before you get the F11 or F14 error or no error coed at all) then I know for sure you need to replace the CCU and Filter... At least that’s what I had to do…I will give you the link to the site where you can buy it....If you have any type of home protection plan I would just call them and pay the service fee (mine is only $50)....its going to be a lot cheaper that way…. If you decide to buy the part or parts…the CCU and the Filter control unit and do it yourself make sure you get the model number off the CCU and Filter control unit. The top cover is just as easy to take off...the CCU will be located in the center on top and the Filter just to its right... Please make sure the washer is unplugged before you remove any covers….I hope this helps....please give me a rating either way...here is that link to the website for those parts….it also gives you a good picture of the parts...Good Luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059617&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=939639&PPStack=1
cbinny1
Posted on Oct 20, 2008
  • 61 Answers
SOURCE: whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Posted on Jan 19, 2009
  • 1294 Answers
SOURCE: Duet Sport. Will not start in any setting.
Get a sledge-hammer to within 2 metres of the washing machine. Then go for the button on the right side "end of cycle" & depress it with your finger for 3 seconds, the control light will come off & I hope you will be able to use your machine.
PS. Remove the sledge-hammer.
Posted on Mar 13, 2009
When I go to make the settings - as per manual it comes up P1 3:20, but when I press the 'menu' button nothing seems to happen. I expected to see P2, P3 etc so my white bread (P1) is terrific
Sometimes the little buttons underneath are not centered properly. Try pushing around the edges of the "menu" selector button your machine makes a "beep" sound" If you never feel the button move under your finger followed by the "beep" sound then your selector menu button may be broken.
Apr 16, 2013 | Russell Hobbs 18036 Breadmaker Fresh Bread...
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
Jun 20, 2011 | Breadman Kitchen Appliances - Others
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down...
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 19, 2011 | Black & Decker B2300 Bread Machine
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
It has stopped-no current at all. Plugs seem to be OK.
Jun 16, 2011 | Breadman Kitchen Appliances - Others
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
Breadman Pro TR875 is stuck & will not start up to knead the dough. Timer is hi-lighted & shouldn't be. No pushing of any buttons will not clear & start over
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    4. Some models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Some models require you press the Select button first before pressing the Start button.
In the end, were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
Jun 07, 2011 | Breadman TR900S Bread Maker
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
Kitchen Appliances - Others Logo
62 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
