Question about Vacuums
Got a small rubber squeezable ball stuck about 2-3 inches from opening Miele silver moon
I just sucked up a small rubber ball..not solid, squeezable. A wee bit larger than a golf ball. It's about 2 inches in....ugh how can I push it out from the other end..Orr can I separate the handle via hose attatchment? I just sucked up a small rubber ball..not solid, squeezable. A wee bit larger than a golf ball. It's about 2 inches in....ugh how can I push it out from the other end..Orr can I separate the handle via hose attatchment?
Take a 3 inch drywall screw or deck screw and screw it into the ball. Make sure that you thread into the ball about at least a half inch. Slowly work Out the ball backwads
Posted on Dec 04, 2016
Miele silver moon vac model s558 serial number nr57365268 what year?
I think it was made in 2008, I found a phone number 1-800-221-8227, maybe they can confirm
Aug 23, 2014 | Miele s558 Silver Moon Vacuum
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
May 02, 2013 | Miele s558 Silver Moon Vacuum
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
My miele silver moon attachment brush stopped spinning. the belt looks good what could it be
It is most likely the hose. There are wires inside the hose that connect the speed and suction control on the handle, to the board inside the canister. After years of use, the wires can become damaged to the point that they wont complete the circuit anymore. Any vacuum store that sells miele will have the replacement hose. You can also get it from miele directly, or off ebay. Be careful going to the vacuum store if you dont have a trusted shop, as they make more money from the sale of a new vacuum, rather than a replacement hose.
Feb 20, 2011 | Miele s558 Silver Moon Vacuum
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
I just bought a Miele s558 Silver Moon, seems like
good vacuums bags are very expensive and parts too
return it
May 11, 2010 | Miele s558 Silver Moon Vacuum
I just bought a Miele s558 Silver Moon, seems like it's from 2000 or so. If it's in good condition, can I expect this machine to last another ten years? Or would it have been better to buy a lower end...
Greetings from GoVacuum,
Ahh, the Miele Silver Moon model S558i. This is great model that I know a lot about because I actually own this exact model. I have had my Silver Moon now for going on 10 years, with almost no problems. The motors in the Silver Moons are excellent, and should last 20 or 25 years without problems. This particular model did have one major problem however. This is the first model that Miele put the suction controls in the handle of the hose of the vacuum, allowing the user to easily adjust the suction setting with fingertip controls. The problem with these models is that static electricity (usually happens when vacuum carpeting) causes the hose to shut down the power to off. You can be in the middle of vacuuming, and all of a sudden the vacuum will turn off. You can easily turn back on the vacuum with the push of a button, but it's irratating for sure.
Miele did come up with a solution for this problem with a newly redesigned hose, part number SES125-3. Since this new design has come out I haven't had a single issue with my hose. The way you can tell if you have the old or new hose is by the numbers (or lack of ) on the different suction levels. If your hose goes up to 1100 Watts, then this is the older style hose. If you're hose simply has a minimum to high setting with no numbers at all on the hose, then this is the redesigned 125-3 hose.
If you have the older style hose, I would get the dealer that sold you the vacuum to exchange the old hose for the new hose, you definitely don't want to have to buy that new hose ($150+). If you have the new hose, then I would say stick with the Silver Moon over the newer Miele models, in my opinion the Silver Moon is one of the most durable models that Miele has ever made.
The only other thing you need to be careful of is the cord reel. When you are retracting the cord reel, it's best to kind of guide the cord back in, and take it slow rather then just stepping on the cord rewind pedal. The cord reel can sometimes be touchy, especially if you are rough with it. If you're careful with it, you should never have any problem with the vacuum cleaner as long as you change the filters on a regular basis as well as the bags.
I hope this helps, if you have any further questions, please feel free to contact me at chris (dot) jones (at) govacuum (dot) com.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Miele s558 Silver Moon Vacuum
My Miele Silver Moon "Reset" light is blinking. What do I do?
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
Miele silver moon vacuum just quit
Usually this is a problem with the electric circuits in the hose / handle.
Dec 17, 2009 | Miele s558 Silver Moon Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
