Question about General Ovens
I have a General electric stove, model number jgb660sej2ss. I need to sink the oven temperature. What setting code should I use after pressing the oven and broil pads?
SOURCE: F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Posted on Dec 26, 2007
RescueTech
  • 145 Answers
SOURCE: oven wont work
If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
Posted on Dec 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: electric oven. temperature problem
Change the temp sensor.
Posted on Feb 21, 2009
TechBrian
  • 15 Answers
SOURCE: digital oven will not turn on, I press bake/broil it reads ''Loc''
Look on the control panel for an icon that looks like a padlock near one of the buttons. Hold that button down until it beeps and that should unlock the panel.
Posted on Mar 21, 2009
  • 417 Answers
SOURCE: Need to replace heating element
Have you tried www.appliancepartspros.com
Posted on Jan 15, 2010
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Why won't my oven let me set the temperature after a power failure?
Good Morning Annette,
I see that you are having trouble with setting the temperature of your oven on your range, model# FGB24S5A, after a power failure. I also see that you have reset your appliance by unplugging it and are receiving an error message of SAG or 5AB. I have looked into the model number that you have listed and it shows as a wall oven. I also do not show either of those error codes you have shown. If you can please get me the model number off your range, so I can better assist. The model number will either be right inside the oven on the back of the door or it may be located inside the bottom drawer. Looking forward to hearing from you.
WP
Apr 25, 2014 | Frigidaire FGB24S5A Gas Single Oven
Icant change the time on my stoves HAP0050 ELECTRIC OVEN,any ideas Thanks
In most cases. Simply press the appropriate button for the feature you want to access, and then use the "+" and "-" buttons to increase and decrease the number values. For example, to set the clock, press the "Clock" button, followed by the "Time/Temp" button; use the "+" and "-" buttons to set the clock to the desired time. When you are finished, press the "Start" button to save your setting. Use the same process to set the oven temperature and timer.
Read more: Whirlpool Stove Instructions ' eHow.com http://www.ehow.com/way_5948402_whirlpool-stove-instructions.html#ixzz1H3LP8Ugo
Mar 19, 2011 | Ovens
My general electric stove oven does not turn on.. code come out f7 and 5 6..what does t mean
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe.
Nov 06, 2010 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
41 people viewed this question
Top General Ovens Experts
Oloyede Monsuru
ray gallant
Melissa Martin
Melissa Martin
Are you a General Oven Expert? Answer questions, earn points and help others
