Question about Coffee Makers & Espresso Machines
In my pump semi-automatic espresso maker when it's finished making espresso there is a little water on top of the espresso in the filter holder when I go to dump it in the trash why is that?
SOURCE: saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Posted on Dec 30, 2007
  • 7 Answers
SOURCE: Breville Die Cast 800ESXL has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Posted on Feb 22, 2008
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: Alessi coban rs04 espresso maker
Hi All,
I had the same problem. There is ONE authorised dealer for Alessi in Italy. They are Arthur Eugster Italia srl, in Asti (Piemonte). I don't have the contact number, but my friend in Italy got a complete set of seals from them, FREE OF CHARGE (don't ask me how he got it) and sent to me in Australia. Good luck
Posted on Jan 18, 2009
Why the water not going up to the pump?
Plz try the following steps if not satisfied plz revert:
  1. Make sure the water reservoir is full and properly fitted into its position.
  2. The grounds should not be over-packed into the filter.
  3. Make sure the filter holder fits properly into the holding ring.
  4. You may need to clean the filter basket and the brew head
Aug 17, 2011 | Franke Saphira Espresso & Coffee Maker
Hi. On the Breville CG10 coffee grinder, is the higher the number the finer the grind or the other way? Thanks.
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Aug 21, 2010 | Breville Coffee Makers & Espresso Machines
Frother not working
Unscrew the plastic frother head and make sure that the plastic and the metal ends aren't blocked. Run a descaling solution through the machine.
Jan 11, 2010 | Gaggia 102534 Espresso-Color...
The machine makes a loud whistling noise when we try to make a coffee?
The coffee solenoid valve can cause such a problem if it very old you must replace it
or the water pressure pump if the bypass it stuck and it produce more pressure than 9-10 bars no need to replace just clean or adjust the bypass.
Please remebr to vote for this answer thanks
Oct 04, 2009 | La Pavoni LaPavoni Bar S3 Semi-Automatic...
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
My bunn NHBx pumps water to fast and it overflows the filter
remove the little rubber stop on filter basket but you now have to wait for coffee to finish before takeing coffee
Nov 08, 2008 | Bunn NHB Coffee Maker
Gaggia evolution- water doesnt flow through the brewer
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Feb 23, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
No water out of the filter spout
Jan 11, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
