I have a pretty aged hd ready to but I need to know how to connect a sa wct 260 soundbar to it ,how pls
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
Mar 18, 2017 | Samsung Televison & Video
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
I have a lg 2540 soundbar connected to my 37inch lg tv. Soundbar works fine on all channels, with the exception of all the HD ones. My tv is connected to a Humax satellite box. Any ideas please.
Maybe the HD channels do not support showing the sound bar via a satellite box connection. Call the manufacturer of the box and inquire with them.
Nov 20, 2014 | LG Televison & Video
I have connected Bauhn 2.0 channel soundbar to my Samsung smart 3D HD TV. But it does not work.
There is probably a sound setup menu on the TV. It needs to be switched to the soundbar. :-)
Oct 19, 2014 | Televison & Video
Connecting an LG soundbar to non optical digital tv
I'm pretty sure your soundbar has more than 1 input. Check your manual. There probably is AUX input on soundbar and that will allow you to connect to TV, assuming that your TV has any audio out. It could be either white and red RCA connectors or headphone jack.
Mar 07, 2018 | LG Audio Players & Recorders
How do i connect a soundbar to this receiver? My soundbar just has a red and white coaxial cable and I can't figure out where to connect to the receiver
Hi there, use your pre-outs, you shuld have pre-outs for all channels, I think the soundbar is supposed to create its own surround effect so I would connect it to the front two channels
May 07, 2011 | Onkyo TX-SR608 Receiver
When trying to connect a phillips soundbar/dvd player into my tv using the HDMI cables/ports - it said it was not HDCP compatible. We tried teh different HDMI ports
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Dec 13, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
Hdmi
Its not designed to play HD DVDs, the model has HDMI connection in order to connect to latest output devices, viz flats panels and LCD tvs there by having a common audio and video cable. your model has a feature to upscale the normal DVD singal to match the quality output of hull HD TVs, hence the HDMI out put, do not confuse this with HD compatiability.
Go to the link below to check the full specs of your system.
http://www.consumer.philips.com/consumer/en/in/consumer/cc/_productid_HTS9800W_55_IN_CONSUMER/DVD-SACD-Home-Theater-System+HTS9800W-55
though yours is a high end set, but its not HD disc compatiable.
Regards
Benam
Nov 14, 2007 | Philips Cineos HTS9800W System
Televison & Video Logo
Top Televison & Video Experts
