Question about Taylor Health & Beauty
We have a Taylor bath scale #7345. An error message comes up as A6EE. What does that mean?
r321567499
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
r321567499
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
  • 39 Answers
SOURCE: I have a Taylor body fat analyzer and scale model
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Posted on Jan 21, 2010
SOURCE: what does the c mean on the taylor weight scale
calibrating
Posted on May 28, 2011
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Taylor 7345
    Take the battery out and hold the on switch down for 10 seconds then reinstall the battery's ( or Plug) then turn on .
    Jun 19, 2014 | Tanita 2204 Body Fat Scale
    My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
    my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
    Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
    Digital readout not readable
    Try a new one. If it works, the scale is broken.
    Jun 30, 2010 | Taylor Precision Products Taylor Precision...
    How can I fix the Taylor LIthium Scale?
    take it to were you got it or instuctions show u
    Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
    I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
    Jan 15, 2010 | Health & Beauty
    ERROR message
    Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
    Error message
    Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
    1. take the battery out.
    2. put the scale on a flat, hard surface
    3. stand on the scale for 10 seconds
    4. put the battery back in, be careful not to touch any buttons or turn the scale on
    5. put the scale back on the flat, hard surface
    6. put one foot on the scale and apply pressure until the display comes on
    7. take your foot off of the scale
    8. wait for the the display to go blank
    9. now stand on the scale to weigh yourself.
    This worked for me. Hope that it works for all of you.
    Dec 29, 2008 | Taylor Dgtl Body Fat Scale
    Health & Beauty Logo
    96 people viewed this question
    Top Taylor Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
