Computer says ip not connecting - Computers & Internet
  • Brett Duxbury
    Brett Duxbury Dec 04, 2016
    Hi nickieboone , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    IP address of computer ? and subnet mask
    IP address of Router ?
    go to dos prompt
    type in ipconfig/all
    press enter
    note default gateway address (should be set as router ip address)
    note pc's ip address
    Top Expert:
  • Computers & ... Master
  • 8,204 Answers
Your computer may be experiencing some sort of hardware conflict or incorrect setting that's causing the system to have an invalid IP address. To force the computer to reconnect to the network, press "Windows-R." Type "cmd," press "Enter," type "ipconfig /release," press "Enter," type "ipconfig /renew" and then press "Enter." You can also use the built-in troubleshooting tool to resolve hardware issues by right-clicking on the network icon on the Taskbar in desktop mode, selecting "Troubleshoot problems" and following the on-screen instructions. Advanced users can attempt to reset Internet Protocol through Microsoft's instructions.
Ads by Google Why Does My Computer Say There Is No Valid IP Address When Connect My...
Posted on Dec 04, 2016
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
How to update a new ip address in order to get my printer print?
I think IP address is not a problem in your printer. You just need to check if the printer driver is install to make your printer work...
IP address is only use to connect the computer to the internet not to connect with the printer. If you have a printer connect to other computer you really need to configure the IP of both the pc to connect each other...
Router will automatically assign IP address of those computer connected to a routers. If you still not connect
Please don't hesitate to ask again and I will give you the step by step to configure your IP address unless your connect with static IP
Sep 20, 2011 | Xerox Phaser 6125 Laser Printer
How do I change the IP address on my laptop?
Simply you can change it by follow the steps below..
Do this:
go to start > run type "cmd" hit enter
in the black box type "ipconfig/all"
record all information
get out of that
go to Control Panel > (classic view) Network Connections > go to your connection and right-click, Properties, TCP/IP settings then Use the following IP address and enter all that info. Except for IP address, change the last part to 254. If it already is 254, then pick any random number below 254.
You can also go in and Repair the connection. Click on the connection, go to the Support tab and click Repair. This will reset the IP but will not necessarily give it a different number.
Finally you can check your ip address at
Jan 20, 2011 | Linksys Wireless-G WRT54G Router
How to connect two computers with one ip
It is not possible to connect two computers with one IP address. This will result to IP address Conflict. If you want to use one IP for two computers, one of the computers can only be on at a time.
Jun 11, 2010 | Compucessory Computer Data (11400)...
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; that is the IP Address of last computer are connected in the network. The IP Address you able to use is, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
Not providing valid IP addresses
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Jan 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
How can i established network connection with ir2800 and desktop
First of all you must have a local network hub.Connect your network hub with your computer and the Ir 2800,your IR have to be equip with a network card.(If only have to connect one computer and your computer is not connected to a LAN network,you can use a cross-over cable connected directly from the computer to the IR machine.Give your computer a ip address by right clicing on the local LAN select properties and select internet protocol ver 4,and select a ip address.If your computer is already connected to a network,dont change the ip address go to command prompt tipe in ipconfig/all.This dos command will show you what the ip address is of your computer.
Example the ip address is,Select a ip address for your IR by changing the last class to any number.But you must make sure this ip is not in use,lets say you select 25.In the command prompt tipe :ping you get a reply,dont use the number.Select a number untill you dont get a reply and a time out response.
Now use this IP address and program it on the IR2800 under additional funcktion system setings,network settings,TCP IP settings.
Switch the machine off for a minute and switch it back on.
Now load the printer drivers of the IR and add the port you selected.
Restart the computer,
And print to your computer.
If you have any trouble along the way,just send me a note
Dec 10, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Brother MFC 8860 has ip conflict. How do I resolve this? The issue is that the IP address is different on my computer versus the printer and thus doesn't allow them to connect. Greg
Each IP-address on a network (private in your home, or public on the Internet) must be unique; hence "IP conflict" when two devices (computers or printers or iPod Touch) try to "claim" the same IP-address.
If you have configured a "static" IP-address into the printer, change it to an IP-address that is *NOT* used on your network.
Or, find the computer on your network that is using the same IP-address as your printer, and change its IP-address and reboot it.
In order to connect, your computer and your computer *MUST* have *DIFFERENT* IP-addresses.
Sep 10, 2009 | Brother MFC-8860DN Printer
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
