What does it mean when you computer says ip dpn't con figerrate
  • Brett Duxbury
    Brett Duxbury Dec 04, 2016
    Hi nickieboone , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    What is the IP address of the computer and subnet mask ?
    Subnet mask would be my guess that it either does not match or you made a mistake in the ip subnetting if using subnetting of ip addresses.
    in english - the subnet mask normally has 255 in its address 255.255.255.0 but when sub netting you might use 255.255.242.0 which changes the ip address range you can use.
2 Suggested Answers
garet83708
  • 20 Answers
SOURCE: What does dpn's mean
DPN, in the context of knitting, means "Double Point Needles"
STS stands for "stitches"
So: pick up stitches of one sleeve plus 4 stitches from cast-on underarms, on 3 double-point needles. Use double point needles on those three stitches so the thread can be doubly threaded per each weave.
Posted on Feb 07, 2014
Windows on my pc says that another computer in my network is using the same IP address as mine, how do i fix this?
you can open the command promp (right click and select 'run as administrator) and enter the command ipconfig /all to get IP address information on each computer (if you want) ...or
enter "ipconfig /release *Con*" to release all matching connections, such as Wired Ethernet Connection 1 or
"Wired Ethernet Connection 2". Note: there is a space between ipconfig_/ and between release_* . You need the spaces too. (not the quotes though)
Nov 08, 2017 | The Computers & Internet
Model number of motherboard installed on dell OptiPlex 745
Look at the old motherboard. There will be a sticker with DPN: followed by a series of letters and numbers. DPN stands for Dell Part Number.
Feb 11, 2015 | Dell Computers & Internet
What does computer command "ipconf/release" do?
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
Sep 03, 2014 | Lenovo ThinkCentre Computers & Internet
Feb 06, 2014 | Computers & Internet
One of my computers wont connect to internet keeps saying limited acsess other computers are working fine
It means there is issue of tcp ip address. Limited connectivity means network adapter tcp ip not correct or not getting ip from DHCP server. For that set static ip in network adapter tcp ip property ac your local network range. Let me know if you need further assistance. Thanks for using FixYa.
May 25, 2011 | Computers & Internet
When logging on, my screen goes white (totally) for a short time (about 30 seconds). and then, i can see my homepage in pieces flickering until it comes in completely. i don't know if this is a computer...
It means taht you may have loose cable connection between the logic board and the LCD panel T-CON board, that will be the first place to look, it can also be that it is losing the 5vdc feeding the T-CON board. Please see T-CON album to see what T-CON board looks like.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br />
Aug 27, 2010 | Envision Computers & Internet
I just bought a laptop for my kids...I have a desktop computer and when I conned the router it disconnects my desktop but I can't get my laptop to work...how do I hook up both?
there could be an IP address clash....r u using one a/c for both the machines ?
try to assign a different IP address to ur new laptop...in ur laptop TCP/IP setting properties...
let me know ur Desktop TCP/IP details....i will tell u what u should do in ur laptop...
does ur router has more than 2 lan ports...or USB ports...???
Dec 25, 2009 | Computers & Internet
Ip address after rest is setting at 169.254.58.1 and the land con
Your computer is not getting an IP address from the router. My guess is that you're trying to connect to it wirelessly without knowing the wireless security settings.
Try connecting directly to it using a network cable, configure the wireless settings and try again.
Feb 05, 2009 | Westell Wirespeed VersaLink...
No Internet connection
First of all I am interested to see the output of this on both machines:
Start->Run->CMD [Enter]
In the Black box type:
ipconfig [Enter]
I would like to see this information if you could be so kind.
You need to check your TCP/IP Settings to make sure they are both set to DHCP which will make it receive a Dynamic IP Address. Also it should set the gateway address for you but you may need to specify the correct addresses for IP, Subnet, Gateway and DNS to ensure immediate access to the internet. Most likely you are in this range but I could be wrong:
192.168.*.* IP
255.255.255.0 Sub
192.168.*.* Gateway
DNS Depends on your ISP but you can find out the information by logging into your router for instance:
http://192.168.1.1 will get you to your router if
your IP one of your clients is 192.168.1.*
Dec 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Dell latitude c640
Hi
Both Dell Part numbers 18THT and 5W299 are 8X DVD-ROM Drive Modules. DPN 18THT is compatible with Latitude C series and DPN 5W299 is compatible with Latitude D series. The two drives have different and incompatible connectors.
Your Latitude C640 is a C Series Latitude. You can therefore not use DPN 5W299.
If you need a DVD drive module, get DPN 18THT or an alternative Latitude C series drive.
Mike
Apr 25, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
