Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Kenmore Elite Freestanding Electric Range - Cooktop not working
We recently installed a new Kenmore Elite 30 in. Freestanding Electric Range into our nearly 50 year old, 100 amp house. We are able to get the oven to work, although it takes FOREVER (30 min) to heat-up. But the big problem is, none of the burners on the cooktop will turn on? They sent us a new stove because we thought the first one was defective. The second one arrived having the same problems. So, now we are starting to think it has something do to with our electrical supply, could this be correct?
  • yadayada
    yadayada May 19, 2017
    You have this wired to a 220V 60 AMP system correct? If no that is why the burners don't work.
    Top Expert:
  • Frigidaire Master
  • 40,304 Answers
Your stove probably requires a separate 20A circuit with 12 ga. wire.
Posted on May 19, 2017
  • yadayada
    needs 220Volt 60 AMP total (30A per 110V leg)
  • yadayada
    You did get the 12 Gage wire right though.
  • 66 Answers
SOURCE: Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
Posted on Jun 16, 2008
  • 135 Answers
SOURCE: Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Posted on Jul 30, 2008
  • 17 Answers
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
Posted on Jun 09, 2009
  • 1723 Answers
SOURCE: Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Posted on Jul 20, 2009
  • 15935 Answers
SOURCE: Kenmore Elite made by Frigidaire
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is can we re-attach it.
Hey Alice, I appreciate your post!
I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
Open the cooktop on a frigidaire fef369cgsd range
Hi Gail Muster - Unfortunately from my research for this particular model it is not possible to open the cook-top without a certified service tech.
Jan 15, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My oven will not get hot at the bottom
If the broil and top portion of the cooktop work, then you are in need of a new baking element. If other settings don't work, your control board needs to be tested.
Aug 06, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How i take the top off
to remove the top to access the surface burners their should ba couple screws in between the lower part of the cooktop and the upper part of the oven door. by opening the oven door and looking up at the bottom of the cooktop you should see those screws.
Sep 18, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Cooktop on light will not shut off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
Sep 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Jan 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
436 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
