Question about Brother Office Equipment & Supplies
My printer brother mfc465cn is over printing, makes all print look blurry
  • 1362 Answers
SOURCE: My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Posted on Nov 01, 2007
SOURCE: brother mfc 8440 "printing" problems
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Posted on Nov 25, 2007
  • 3 Answers
SOURCE: 8400 blurry print
I had a similar problem. I discovered that the imaging drum was too hot. There is a temperature sensor that rides on the drum surface to monitor the temperature. You can see it if you lift the exit cover on the right side. The sensor is white, and has a thin probe which rides on the drum surface. There's a single screw accessible from the right side which holds it in place. A hole on that side will allow a screwdriver (torx) to access the screw and the little unit can be removed (be patient- it can be done!). Clean the probe with some alcohol and replace it. The problem is caused when the ink on the drum smears because it's too hot. Dirt (wax and oil)under the sensor probe prevents contact with the drum, and makes the printer think the drum is too cold.
Posted on Apr 08, 2008
SOURCE: My brother printer in printing blurry?
I have bro-420C. Same problem. I used the option Ink. There is "cleaning" option. It helped to make it much better.
Posted on Apr 18, 2009
  • 94 Answers
SOURCE: My Brothers MFC 210C All-In-One Inket printer is
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply
Posted on Aug 16, 2009
How do I fix this, my printer is printing double letters and showing "unable to print 32"
Print a pic. Scan. Print scan. See if print is wrong. If so, the machine needs re-callibration; machine program should be able to do this.
Oct 17, 2014 | Brother Any 4 Inks Mfc-465cn Mfc465cn...
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
Brother printer mfc465cn magenta color not printing
The print head may be plugged. there is a procedure to clean it in the printer maintemance menu
Dec 30, 2013 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
My MFC465CN Wont print, I am missing Magenta will that affect it?
Yes missing the magenta ink will cause it not to print. This is because its a color inkjet machine that uses one printer head for all four inks, so when one of them go empty you will need to replace that one for it to work.
Jun 25, 2010 | Brother MultiFunction Center MFC-440CN...
Blurry printing
Go into your printer maintenance menu ;-
Start - Printers and Faxes - RMB brother printer - Properties - Maintenance.
May 11, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i align my printer, it's printing blurry but copies fine
the problem is with the main board. I fixed two of the exact same problem before.
May 28, 2009 | Brother Multi-Function Center MFC-240C...
Nov 20, 2008 | Brother HL 5250DN Laser Printer
Printing labels
make sure that you are using labels marked for ink jet. nexr you will need to clean the paper feed rollers on the machine with with denatured alcahol which you can get at a local hardware store
Aug 06, 2008 | Brother MFC-465CN InkJet Printer
The head probably needs aligning.
An interum fix is to turn off bi directional printing in the preferences.
This could possibly solve the problem.
Jun 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
James Cagle
James Cagle
Jim Keysor
