Question about Bosch Ovens
Bosch top/bottom oven loud rattling noise can be stopped by turning off supply?
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
SOURCE: Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
Posted on May 16, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 200 Answers
    SOURCE: Fan rattling in Hotpoint BS41 oven
    Hi
    Check this link
    http://repair2000.com/oven.html
    Posted on Sep 16, 2008
    barkencoa
    • 3463 Answers
    SOURCE: just brought a bosch oven and there no life in the bottom oven
    If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
    Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
    Hope this helps.
    Plz rate my solution.
    Thanks.
    Posted on Jan 03, 2009
    My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
    The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
    May 16, 2016 | Smeg Ovens
    Bosch oven will not turn off
    New oven? What about the supplier warranty? Bosch is a top make, get hold of a dealer.
    Nov 14, 2014 | Ovens
    The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
    From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
    Hope this helps.
    Feb 02, 2010 | Candy FP855 Electric Single Oven
    Bosch oven loud fan noise
    JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
    Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
    Fan making loud noise
    Hi
    does the noise start as soon as you turn the fan oven on?
    does the noise stop as you turn off?
    just depending what make and model you have there is two fans
    in it 1 is the fan motor inside oven at back and other
    is the cooling fan which is at top of oven .you just need
    to find out which one it is and just replace . then should be back to normal
    regards dan
    Mar 19, 2009 | Belling XOU174 Electric Single Oven
    Bosch convection double oven,ovens won't heat,only broilers work
    If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
    Plz rate my\solution.
    Thanks.
    Dec 17, 2008 | Bosch Ovens
    May 16, 2008 | Amana AEW3530DD Electric Single Oven
    Ovens Logo
    Top Bosch Ovens Experts
    ashburton
    paulcarew
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
