Question about Panasonic Microwave Ovens
My panasonic sensor 1250W microwave cuts out after 3 seconds.
MicrowaveSvc
  • 9098 Answers
SOURCE: cleaning interior of microwave door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Sensor 1250W Microwave cycles off after only 5 seconds.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector.
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US, see Panasonic.net.
Posted on Dec 26, 2009
Testimonial: "Extraordinarily helpful, comprehensive advice within 24 hours of posting my question. Thank you so much!"
  • 534 Answers
SOURCE: Where does the fuse go in a Panasonic Microwave
Follow the power line from the outside to the inside towards the magneto the fuse will be located inline. You have to remove the outer shell of the microwave to access this area. Also do not touch both sides of the fuse terminal at any one time due to a nasty shock from the capacitor
Dave
Posted on Jan 13, 2010
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Posted on Apr 24, 2010
SOURCE: panasonic inverter genius sensor 1250w, turns on
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Posted on Mar 01, 2011
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
I have a Panasonic Genius Sensor 1250W that went on "demo" mode when the power went out and we don't have a manual to get it back on regular mode. Any suggestions?
http://www.generalmanual.com/Microwave-Ovens/Panasonic-NN-P794SF-Microwave-Oven.htm
click on the above link it will take you to the correct site to download all service and operation manuals for your panasonic m/wave
Jul 01, 2011 | Microwave Ovens
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
Feb 09, 2010 | Panasonic Microwave Ovens
Dec 25, 2009 | Panasonic Microwave Ovens
Panasonic 1250w buzzing noise in first 3 s and then stops abruptly regardless of time set. Gives a faint burning smell when opened.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Jul 27, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
