Have a Remington space heater, runs for approx. 10 min. then shuts off, then if unplugged or switch turned off, then it will start again for short period of time
    Top Expert:
  • Heating & Co... Master
  • 42,927 Answers
There may be an overheating sensor that is causing shutdown after 10 minutes. After a cooling off period, it is ready to heat for another 10 minutes.
Posted on Dec 04, 2016
How do I fix my forced air heater?
Check for sensors on the unit that might be failing. I think many heaters have safety interlock switches on them now.
Overheating... Too Hot
Position Sensor... Knock it over & it turns off.
Loose wires....
Obviously turn it off when looking inside
Good Luck
Feb 21, 2015 | Heating & Cooling
Location of fuel pump relay switch in 1992 olds silloutte 3800
It is under the Hood, in the Fuse Box. Go to this web site and put in your information and you will see the diagram
www.bbbind.com
Apr 15, 2013 | 1992 Oldsmobile Silhouette
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
9200 weather maker does not seem to blow heat, it will trip limit switch at fire box, smeels like unburned gas when running, what might be the cure.
i turn my heater on, then it shuts off 3-4 min later, approx. 10-12 min l8r it turns back on... the fan doesnt run enough to cool, or heat my home... im cold and kinda upset about the whole situation... anyone got a clue?
Apr 30, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
