Question about Cell Phones
How do I answer an incoming call on my Hisense F20 smartphone
Can I pair Bluetooth earphones to my hisense smart tv?
Only if the television is Bluetooth enabled. Check the documentation. Hisense is a budget television. If you have a smartphone you can check Bluetooth settings and see if the television is putting out a Bluetooth hand shake.
Jul 27, 2017 | Hisense Televison & Video
Hisense u1 touch screen problem
I have a Hisense U1 smartphone that has developed dead zones in the middle part of the screen. Letters like t,y,u, g,h,v,b are not responding in the portrait mode. The same to the extreme left of the screen affecting letters q, a. Any solutions?
Jul 21, 2013 | Televison & Video
I have a 4000 Series Maytag Frontload Washer that is blinking with a F-20 error code. I am trying to find out what this means.
The F20 code usually means a washer fill problem. It could be low water pressure or no water pressure. Check that your water valves are open on both the hot and cold inlets. Check the hoses for kinks or damage that interrupts the water flow. Check for debris in the inlet filters and clean the filters. Some anti-flood hoses can close their internal valve if the water pressure builds up. This could cause the machine to see no water pressure. What is your water pressure (it should be above 10 psi)? If you have a water well, this could could give low water pressure to the washer and trigger the error.
Replace the hoses if needed. If you have a High Efficiency washer, make sure to use HE detergent. Excess suds could cause the incoming water flow to be judged as low.
See http://maytag.custhelp.com/app/answers/detail/a_id/2887/~/display-shows-f20-or-fh---front-load-washer for details.
I hope this helps.
Jun 28, 2011 | Washing Machines
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
Jan 11, 2011 | Whirlpool WFW9400S
A times when answering an incoming call I do not
This problem from the earpiece it should by replaced
Apr 11, 2010 | Nokia 5800 XpressMusic Smartphone
How do you change answer mode on a blackberry pearl 8230
To use Auto Answer and Auto End on the BlackBerry smartphone, complete the following steps:
1) On the Handheld press Call button.
2) Press the Menu key.
3) Select Options.
4) Select General option.
5) Select Auto answer calls to, Out of holster.
6) Select Auto end calls to, Into holster.
When a BlackBerry smartphone user takes the BlackBerry smartphone out of a holster, incoming calls will automatically be answered.
When a BlackBerry smartphone user puts the BlackBerry smartphone into a holster, ongoing calls will automatically be ended.
I hope i was able to help you.
Thank you for using Fixya.
Nov 08, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
CAN NOT LOCK THE DEVICE
its not possible in this cell phone
Jun 02, 2009 | HTC Touch Pro Smartphone
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
