Question about Saws
Putting cutting wheel on rigid R4020 tile saw.
  • 2712 Answers
SOURCE: Tile Saws for shor and vurved cuts
A 100mm angle grinder is used for that kind of work. It can also be used for "L" shaped cuts and for making holes. It is usually being used dry and more rarely used wet
Posted on Aug 27, 2008
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
SOURCE: need to purchase replacement part for a wts200l rigid tile saw
Posted on Apr 12, 2009
  • 32 Answers
SOURCE: how do you square the rigid tile saw to cut
take a framing square and set it aginst the back stop.
then loosen the screws that hole the saws arm to the base.
now set the square aginst the blade and adjust untill it is even,in the front and the back.once you have acheved this tighted the screws on the arm to hold .
Posted on Nov 06, 2009
  • 8 Answers
SOURCE: tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Posted on Jul 22, 2010
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
How to cut glass and metal tiles?
You will have better luck with a hand glass scorer, looks like a pen with a score wheel at the bottom and the tube is filled with oil (like a sewing machine oil). If you want to cut each tile individually, then snap the tile by holding each side with a pair of snubby pliers wrapped in tape (slippery otherwise) You can get a glas scoring pen at craft stores with stained glass supplies or a stained glass supply shop or online. The wet saw is used to cut a row of the tiles at once, which is most efficient. The sliding tile scorer would be too cumbersom to hold the small tile in place and try to cut.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
May 01, 2015 | Saws
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
How to lower the blade it's not cutting all the way thru..stand. 12 inch please
a temp fix,put a thin rubber mat under your bridge saw does plunge cuts & has a knob on side of cutting head, your blade must have been changed somewhere even if changed with the same size blade some vary in overall size,good luck
Nov 05, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
While using the rz10 tile cutting wheel the saw has no tourque any kind of resistence the wheel stops
The only tile that they are any decent at cutting would be ceramic, slate, or terracotta. Anything else is way too hard and even cutting the listed tile it's no joy to do. I would suggest using a 4 or 4 1/2" grinder with a diamond blade coupled with a wetsaw. hope this helps and good luck.
Jan 02, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
Wobble blade /rough cuts
You may wanna check the Conveyor Cart Wheel. Replacing this wheel maintains smooth rolling action which contributes to straight, chip-free cuts.
It costs for only about $28.72. Here, you may check this link if you wish to buy the Conveyor Cart Wheels:
Unfortunately, I couldn't find any service center where you can bring your Target Tile saw for repair. But you may check the manufacturer's contact number on the user's manual.
Have a great day!
May 30, 2009 | Target Saws
Need to purchase replacement part for a wts200l rigid tile saw
Mar 11, 2009 | Saws
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Saws Logo
130 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
