Question about Intex Pool & Spa
HOW DO I REPAIR THE BUILT IN PUMP ON THE INTEX AIR FLOW BED
5 Suggested Answers
  • 297 Answers
SOURCE: pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Posted on Jul 15, 2009
fawkwindows
  • 96 Answers
SOURCE: Our Intex air bed has a leak, we think the leak is
Guerilla repair it by replacing the valve by cutting out the valve add a new valve with extra rubber and, rubber cement.
Posted on Dec 27, 2009
GodBlessU
  • 3513 Answers
SOURCE: i have an intex above
Hi
The Intex system has an LED that displays various codes when a problem occurs. After one hour of the code flashing and the system beeping, the unit will turn off and not produce any chlorine.
Check the screen for the code that is being displayed. If the unit has turned off, press either the down or up arrow button below the screen to see the last code displayed.
Refer to the owner's manual to identify the code and the meaning. There are three codes that can display. Code 90 is low or no water flow, code 91 is low salt and code 92 is high salt.
Code 90 means the filter is not on, the hoses are clogged, the filter is clogged or the water is flowing in the wrong direction.
There are several things you may need to check and do:
- Ensure the pool pump is on and running.
- Ensure the plunger valves on the pool (if any) are opened.
- Ensure the filter cartridge, cell and debris screen are clean from debris and dirt.
- Ensure the flow sensor (especially the hinge) is clean. See Owner's Manual. Release all trapped air (if any) in the circulation line hose.
- Check he direction of water inlet and water outlet hose. Reverse the hoses if incorrectly connected.
- Check if the flow sensor is loose or not connected properly. If not, please plug the flow sensor firmly into the flow sensor receptacle.
- If code 90 still appears despite above steps, there might be a flow sensor failure. Please contact Intex Service Center for replacement.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 20, 2011
  • 368 Answers
SOURCE: Intex pump strongly pulls water
It is likely that your filter is dirty. The filter's cartridge can be removed and cleaned with a spray nozzle on a hose. you will then need to reassemble, prime and restart. I hope this helps.
Posted on Aug 09, 2011
Pump on my Intex air mattress shuts off before the bed is inflated
Pump is ng and needs replacement. Take it back if under warranty.
May 03, 2017 | Intex Pool & Spa
Does the pump on an Intex Bed 58627/68627 stop filling automatically?
no but it does change pitch of sound it makes as bed fills up that could fool you to thinking its stopped
Jun 26, 2014 | Intex QUICK-FILL ELECTRIC PUMP, AC 110-120...
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
Top of bed has a small hole
use Bubble gum or a ready made puncture for i t
Dec 10, 2013 | Intex Ultra Plush Queen Air Mattress Bed...
No water flow e90 fault code intex pure spa
Unplug the unit. The E90 code on the intex spa is due to a dirty water flow sensor. Remove the control panel and all the screw holding the casing on. In the white plastic piece on the discharge, top hose, you will see a silver nut with a black wire coming from it. That's the sensor. The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business!
Sep 27, 2013 | Intex 10x30" Metal Frame Pool w GFCI
It leaks throu the pump
i've never heard of an inflatable bed that you leave the pump hooked up to. I would suggest pumping it up removing the pump and put the plastic plug back into where the pump was attached
Jul 14, 2012 | Intex Rising Comfort Queen Inflatable Bed...
After modifying our 20x 48 Summer Escapes pool to utilize our Intex Saltwater system - why is the saltwater pump showing low flow?
Index salt chlorinators need a certain flow rate. Check the flow rate on your pump to see if it is strong enough.
Mar 27, 2017 | Intex Pool & Spa
Our Intex air bed has a leak, we think the leak is in the valve. over night the bed deflates, ugh.
Dec 22, 2009 | Intex AIRHEAD Performance 1-Person...
Pool & Spa Logo
106 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
