Question about Humidifiers
We have had the humidifier for about a month and have used it 6 times it was working great the next day it stopped. it just makes a whistling sound. no mist. We also put it up off of the floor.
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
SOURCE: Cool Mist Humidifier Filter Drying Out
Do you have tried to use without filter?
Posted on Jul 17, 2008
SOURCE: Sunbeam Ultrasonic Humidifier 696-12
tentative on the Solution icon ...
I picked this up a couple days ago at the Salvation Army, 3 bucks. I also had way too much damp coming out, saturating anything near.
I read through the comments, and one folk said they uncovered the spaz unit and tightened the screw they found there, to no avail. They asked if they should reopen and loosened the screw ...
Which I did. Took me a while, and maybe those who aren't used to investigating the inner workings shouldn't try it unless they're willing to make a mistake and throw it away, but ...
I loosened the screw. Not sure if it was a quarter turn or a half turn; I wanted to do more and have learned many times that "more" is not "better."
I have a cardboard box in front of the unit for hours now, and it is not saturated.
The factory setting, whether it be for all or some, is too wet. Loosening the screw that shows through the computer board has, for me, made the unit more tolerable. Takes an eyeglass-screwdriver to get it done, but if'n ya has the general know-how to investigate things, maybe it'll work for you.
Posted on Jan 07, 2009
  • 8 Answers
SOURCE: humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
Posted on Jul 03, 2009
SOURCE: Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Posted on Feb 10, 2010
It runs but does not put out any mist.
You didn't specify the brand or model, but for generic advice, try using a strong solution of white vinegar and water and soak overnight or for several days (if very scaled up).
If you were using hard water in the humidifier, try using a commercial humidifier cleaner such as BestAir products (or similar - there are many to choose from): Amazon com BestAir 3US 6 UltraTreat Ultrasonic Vaporizer Water Scale...
(Make certain it's certified for steam and/or ultrasonic use, if your using that type of humidifier).
Follow directions on box. You will have to let soak for a period of time (hours/days) to allow chemicals to do their thing.
If you are using "soft" conditioned water, just refill with soft water and allow to sit for several hours, then discard and refill. The hardened minerals will re-disolve and will be removed when you flush the unit. For hardened minerals clinging to the sides, etc, just use your fingers to break up, possibly a brush or Dolby pad and break them loose.
(Soft water has just as much minerals as hard water, but in hard water there are mostly calcium based and turn rock hard and in soft water they are sodium based (sodium bicarbonate actually) and have a weak structure).
It's important to keep a humidifier clean of deposits, not just to keep the unit running, but to avoid air quality problems (bacteria will cling to scale buildup, which make excellent breeding grounds for them).
If you use "hard" tap water, clean (at a minimum) once a week. Use white vinegar and water - 50/50 mix. If your using "soft" conditioned water, clean once a month. Same with distilled water.
You could also consider using a small amount of bactericide in the water to prevent bacteria from growing. (Okay for filter type humidifiers, but DO NOT use in ultrasonic or vaporizer type humidifiers). 1/4 cap full should suffice. BestAir 3BT 6 Original BT Humidifier Bacteriostatic Water Treatment 32 oz
Jan 03, 2016 | Humidifiers
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
We left the humidifier with the water tank half full for a few months, then realized, cleaned veerything up with vinaager as for instruction manual, refilled with water, but we turned on the humidifier is...
Brother, I think you're OK here. I run a couple in my shop, both cheap from Walgreen's, and I'd be ruining the suckers once a week if they didn't have auto-shut-off. Your's should too. Sounds defective.
Dec 12, 2017 | Vicks V5100N Humidifier
The Honeywell HCM-6009 humidifier unit no longer turns on. This was an abrupt change--not sure what happened. It was working fine one day, and the next day it was dead. Is there anything I can do to...
Save the time and frustration these units are hard to work on. Make sure there is power to the unit other than that throw it away and buy a new one for $100.
Aug 19, 2011 | Honeywell QuietCare HCM-6009 Humidifier
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
SlantFin 210W stopped working
The dehumidifier may have been on its last legs when you received it.
Dec 10, 2017 | Slant Fin GF-210W 2 Gallon Humidifier
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
New Aprilaire 700 - loud hi pitched whistle
You may be having problem with air scaping from the base of the hum. it will probably may have to put silicone around the base of the hum. to stop the air scaping.
Feb 05, 2009 | Aprilaire 700 Humidifier
Loud "Glonk" when humidifier turns off
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Mar 12, 2008 | Aprilaire 700 Humidifier
Noisy humidifier
A noisy humidifier may be the result of an unlubricated fan motor or a drive mechanism clogged by debris. Periodically clean the water reservoir, fan, and nozzle to ensure that they are clean and working properly. To keep your humidifier working smoothly and efficiently, lubricate the fan motor bearings with SAE #20 oil. Be sure to consult your owner?s manual for proper care and maintenance procedures. If it seems loose, vibrating parts are causing the noise: 1) Disconnect the power. 2) Remove the cover and look for any vibrating parts. Tighten screws, if necessary. 3) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor's bearings if suggested in your owner's manual. 4) If it still makes noise, call an appliance repairperson or take the unit into an appliance repair shop.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Humidifiers Logo
53 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
