Question about Kohler Plumbing
I have a Kohler kitchen faucet K6131-4-CP. the faucet is leaking but when I shut off the hot water valve under the sink, it stops leaking. What is the problem and how do I fix it?
    Top Expert:
  • Kohler Master
  • 39,413 Answers
The faucet probably is leaking at the base, a common failure. The only solution is replacement.
Posted on Dec 05, 2016
Kohler single handle kitchen sink replaced valve kit cartridge turned water on but no hot water replaced hot water angle stop valve turned hot water on and get nothing hot vale is open no water help
-Only at the sink has no hot water...?
If yes then:
-Make sure the valve on the wall is Turn On.
-If not sure which way then turn faucet on and then turn the vale on to either side to find out.
Good luck
Mai
Nov 01, 2017 | Kohler Plumbing
The kitchen sink faucet is clogged
If it just the hot or just the cold then it will be the shutoff valve not the faucet. replace the valve/s under the sink Try checking the screen in the head of the faucet for sand. If it does not have a screen(some dont) then it will have a restrictor usually green in color that may have debris inside of it.
Jan 06, 2013 | Kohler K-692-VS Clairette kitchen sink...
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
Leaking hot water seal
leaking around handle?Turn water off under sink.remove handle,cover plate,unscrew valve stem assembly,and turn the two pieces apart to expose o ring,and replace
Jan 27, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Just lost pressure. Only a very small stream of water comes out, hot or cold. All other faucet in the house work fine. It is about 1 1/2 years old. R10433-CP
First try the tip ariator. it can plug up. then you have to check the inlet system, which includes shut off valves, hoses to the faucet and the cartridge. It is the cartridge that has the small openings, but shut off valve seat material falls back into the feed channel. I usually remove cartridge, cover with a towel and turn on feed water briefly. Often I get little pieces.
Oct 27, 2010 | Kohler Model 10433: Fort® Single-control...
Kohler K-16109-4 Revival Kitchen faucets (two handle): When I turn on the HOT water handle and let it run, I get a small leak out of the COLD water handle. When I run cold, no leak. Does this just...
There is definitely a problem with the cold valve if it is leaking, but it seems odd that it doesn't leak when it is on. If I was doing this, I would replace both valves.
Nov 14, 2017 | Kohler K-16109-4-CP Revival Kitchen Sink...
My Kohler single lever pull-out faucet stopped working. Raising up does not start water flow. Turning left sometimes starts some hot water, but raisinglever up and down does not start or stop water flow as...
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
Apr 28, 2010 | Kohler Model 10433: Fort® Single-control...
Cannot remove Kohler ceramic valve
is this a single handle faucet. If not the part goes in under the handle
Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
Kitchen faucet
look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Mar 13, 2009 | Kohler Forte entertainment remote valve...
Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Nov 12, 2008 | Kohler Forte entertainment remote valve...
Plumbing Logo
299 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
