Question about Bosch Kitchen Ranges
Error 43 In a Bosch range lock code oven door not openning
3 Suggested Answers
  • 1314 Answers
SOURCE: Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Posted on Jul 13, 2008
rickead1
  • 1998 Answers
SOURCE: Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Posted on Apr 30, 2010
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
I have a Bosch HEI7282U range. Went through self clean cycle, oven cooled down but oven door will not open. Put through another self clean, door still does not open. Cut power at circut breaker for over 5...
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut
Jan 31, 2011 | Bosch HEI7282 Electric Kitchen Range
Started to bake an item, so I preheated the oven and started to cook item when all of a sudden an error code came up and stopped the oven from baking any longer. THE CODE( F95 ERR) came up and shut the...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 23, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
Oven has f90 error code and door stays locked cannot get oven top door
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Aug 27, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Apr 30, 2010 | Kitchen Ranges
F93 error code
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Bosch convection oven in self clean mode, am getting an error code of 41
Hi, I am getting the same error today. Did it ever clear up? Were you able to open the door eventually?
Jan 24, 2010 | Bosch Evolution Pro-Style 700 HDS7282U...
I have an error code 45
As per Bosch,
Error Code: F45 Cause: Upper (or single) oven latch both locked and unlocked; Defective or jammed upper oven door or latch switches. Corrective Action: 1. Check P4 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are pinched to the appliance chassis. 4. If F45 persists, replace power board
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Error when self-cleaning - oven locked
Here is the error code and things to check on your oven.
Error Code: F41 Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check that the solder joints in header P24 on the power board are not broken. 5. Check P10 connector and check if latch motor wire is
Regards
Alan Hood
ami-man
Dec 04, 2009 | Bosch HES5042US / HES5052US Electric...
Kitchen Ranges Logo
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
