Question about Vacuums
My power button eill not stay down vacuum will come on when power pushed down but when released vacuum goes off. If button is held down I can vacuum but get a burning smell?
I have DC07
SOURCE: Dyson DC07 burning smell.
sounds like it is on the way out this may be because 1, you need to clean the filter cos when its dirty it stop air from going around the motor witch makes it get hot and overheat 2, also if you allow the bin to get to full this will also stop the motor from geting air to it so a good clean on your filter and bin will allow air to the motor then no overheating should accur
Posted on Jun 17, 2007
SOURCE: Dyson dc14 power button
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
Posted on Nov 30, 2008
  • 174 Answers
SOURCE: Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Posted on Jul 05, 2009
  • 438 Answers
SOURCE: Power Button won't stay down/on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums2_bing.gif . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Pliers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay the vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson Vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose pliers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose pliers to reattach the wires to the new switch, but it also can be done with just your hands. Both both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya.
If you ever need any for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
If this was helpful, please be so kind and leave feedback for the repair. This is really, really appreciated and is the reason repair professionals like myself continue to post free repair help on Fixya rather then just answering the paid questions.
Thanks again,
Chris J.
Posted on Apr 17, 2010
  • 10 Answers
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Posted on Jul 28, 2010
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
Jan 10, 2017 | Dyson Vacuums
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
On button won't stay depressed. when pushed to on, the vaccuum goes on but won't stay on unless button is held down.
Needs a new on/off switch. You can order one from an appliance parts store, and replace it yourself or take it to a shop.
Feb 15, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Animal DC17 motor won't stay on
You will need to have the button replaced. Dyson power buttons are notorious for breaking because just a gentle push is all that is required and they can break if they have been pushed down roughly.
Apr 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Power Button Problems
Sounds like the switch is faulty & will need replacing.
Jan 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Won't stay on!!! HELP!
It is the on/off switch that needs replacing. It can be done at home if you know someone who would attempt it. Overall, knowing that it is the switch, it should save money by not having them troubleshoot further. Tell them what I told you and it should be cheap. Good Luck.
Nov 20, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
