Question about Hansgrohe Plumbing
My bathroom faucet leaks at the base. similar to hansgrohe metro e. I checked the O ring - fine. Faucet still leaks How I get a good seal between the O ring and the faucet? Tim fisher
    New Friend:
  • 20 Answers
Check your cartridge and seat if your not sure what they are you can you tube it I'm sure there would be a video explaining how to change them. It is not very difficult.
Posted on Dec 10, 2016
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 72 Answers
SOURCE: stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Posted on Aug 08, 2012
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
SOURCE: how to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Posted on Oct 12, 2008
SOURCE: I have a Hansgrohe kitchen faucet model P-IX
Is this the Axor model with one handle? Of so you need to get a new element - the central piece inside the faucet - from Hansgrohe which costs about $45. It comes with a little repair kit that has very low quality instructions.
You need to use a metric tool #3 to unscrew the little piece in the back of the handle - then the handle comes off. You have to pull it hard to get it off.
The repair kit that comes with the element has a tool to screw off the main collar of the faucet and pull out the old element. The tool is a piece of junk that bends out of shape immediately and doesn't open the collar, and possibly cuts your hand in the process. Somebody at Hansgrohe was too busy having a coffee break to figure out that by the time you repair one of these units, it's probably been in service for several years and has a good deal of corrosion and means you need to good solid tool to unscrew the collar. The tool they send is pathetic. It's actually better, if you can, to use the side of it across the two niches in the back of the collar to make the turn. You may need to give the collar a few whacks with a small hammer to loosen it, but be careful not to hit the visible part of the faucet, is it will dent easily and not look so great after you complete the repair. Once you get the collar out the replacement isn't very hard. I've done this repair twice and am so irritated by the lousy instructions and bad tool that I'll never buy another piece from Hansgrohe.
Posted on Jan 10, 2010
Flip over bathroom plug in bath stuck & bath full :/
follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Nov 28, 2013 | Home
Hansgrohe axor repair
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 | Home
Adjust handle stop on Metro high arc
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
How do I fix a leaking hansgrohe solaris bathroom faucet?
If this is a widespread faucet you will need to turn the bell shaped portion of the handle counter clockwise to remove the handle as one unit. Then you will see the hex nut of the cartridge that will unscrew counter clockwise to remove. If this is a single hole unit you will need to loosen the set screw on the handle to remove it and then remove a cover ring to access the cartridge nut. If you need any further assistance feel free to call me at Hansgrohe. 1-800-334-0455 press 2 for Tech and ask for David Scarborough. I'll be happy to help.
May 25, 2012 | Hansgrohe Plumbing
Faucet leaks when water is turned on at the spout base. I took the set screw out of the back but can,t remove it to access the orings or seals
better turn off the main line first, screw the ring again putting some extra pressure because usually rings are tighten so hard.you have to replace the base of the faucet.
Jun 22, 2011 | Banner Faucets Castille 700 Vintage Series...
Hansgrohe 06566860 Metro Single Hole Kitchen Faucet periodically makes noise and reverts from needle spray to full spray by itself. Have to press on needle spray indicator on top of sprayhead 4 or 5 times...
make sure the hose under the sink, ( the one that goes to the faucet) has not gotten twisted around anything. sounds like it is losing pressure. it takes steady pressure for the stream to maintain that "needle" spray.
Feb 15, 2010 | Hansgrohe 06649860 Solaris Single Hole...
I have two leaking bathroom faucets. Hansgrohe 06042. I replaced both faucet valves from Hans part no. 94009000. They BOTH still leak steadily. They worked flawlessly for two years.
where are they leaking from?
if they're leaking from underneath, repace the suply lines [between the valve and faucet]. if if from the faucet itself replace your cartrage[s].
Aug 18, 2009 | Hansgrohe 06042 Tango Widespread Bathroom...
One handle kitchen faucet leaks
There are "o" rings in the area where it is leaking. You can get them at almost every hardware chain. Clean everything well with scotchbrite ant put silicon grease on before you put it back together.
Feb 21, 2009 | Kohler K-10416-BN FortĀ½ Single Control...
Spray head leaks out of the top of Metro 06917000
Here is a link to the PDF for that particular model:
Spare parts catalogue
Here is a link to the faucet page if this isn't what your looking for:
Metro 06917000
Hope this helps!
Nov 29, 2008 | Hansgrohe 06649860 Solaris Single Hole...
Plumbing Logo
282 people viewed this question
Top Hansgrohe Plumbing Experts
GCcontractor
Jim Goldsmith
Jim Goldsmith
Andrew Bugbee
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
