How do I de-program my thermostat ? I want to only have ambient temp displayed and I manually raise or lower the temp, as if I had an non-programable model
  • 518 Answers
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
Without a model number, it's hard to help Ya out, but most manuals are here: http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
Geno
Posted on Jan 23, 2008
  • 833 Answers
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Posted on Nov 13, 2008
tborn6
  • 700 Answers
SOURCE: How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Posted on Dec 31, 2008
machtcl1
  • 61 Answers
SOURCE: My furnace works intermittently.
You may have a dirty flame sensor. There are a number of other possible causes as well. Rheem/Ruud/Weatherking furnaces also have problems with the connection on the blower deck.
The flame sensor sometimes must be bypassed around the MOLEX CONNECTOR in the deck due to humidity.
Hope this helps.
Matt
maxhtcl1@verizon.net
Posted on Jan 15, 2009
  • 4 Answers
SOURCE: ambient temp guage problems
The temperature sensor is located in front of the radiator on the passenger side. Replacements cost approx $25.00.
Posted on Mar 04, 2009
Just installed a T6 Pro thermostat. I need to adjust temp and it’s set to 68 and will go no lower. How can I accomplish this?
If you read the manual it should help. Sounds as if you are trying to run a program but on a newly installed tsta t the minimum cooling setpoint should be 50. Not sure why it's stopping at 68 unless it's not new or not working properly. Read the manual and turn programming off and lower the minimum cooling setpoint temp.
Jan 31, 2018 | Heating & Cooling
Tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 | Heating & Cooling
Robert Shaw thermostat keeps resetting to 35 ambient temperature.
perhaps finding and reading the manual will help , here is a list from Google Robert Shaw Google Search
Oct 03, 2015 | Heating & Cooling
Time and vacation symbol flash-all buttons non responsive - how do I fix
Hello there,
Are you SURE the floor temp sensor is wired correctly Page 8 of the Manual ???? It should be across 1 and 2 . if it was on the number 2 and 3 connections, this would simulate a 'remote switch' check the wiring of the floor sensor carefully in the back of the unit.
Something odd about the 'Vacation'mode' setting. You said it has no remote switch but only this 'remote switch' can disable it. by going open circuit. which sounds suspiciously like something is across pins 2 and 3
Time flashing is 'Temporary override'
Read page 16 AND 17 (flashing as you say) of the user manual
https://customer.honeywell.com/en-US/pages/product.aspx?cat=HonECC%20Catalog&pid=TH115-AF-GA/U
Click literature and download.
Sep 22, 2014 | Honeywell Aube TH115-AF-GA 7-Day...
1992 buick cenyury dual climate controls with settings both full hot with digital display reading 90 with vehicle warm restarting first comes out hot after running for a few mins then 90 degree digital...
look like the program is not working. if the set temp, is lower than the real temp, heather should come on.
if the set temp is higher than the ambient temp. the ACC should come on.
I will try one first, then setup the other.
Jan 21, 2014 | 1992 Buick Century
Why is it displaying "temporary"?
The automatic programming has been overridden to, for example, increase the heat temporarily until the thermostat is returned to automatic operation.
Jul 03, 2012 | Honeywell Electronic Programmable...
My thermostat defalts to 60degrees on weekend right about eight in the morning. it raise it back up but at 10:00 pm it defalts back to 60. Ihave it set for a daily temp at 68. works fine during the week.
You didn't indicate the model # but it sounds like it is defaulting to factory program 2 on the weekend. For information on operating and programming visit Hunter Thermostat Manuals and enter your model # to view and download the manual.
Feb 06, 2011 | Hunter Fan Company 5/1/1 Programmable...
How do i set a hunter theromtate #441100. i don't
Set the temp you desire and hit "Hold temp" or "program overide"
Hunter thermostats are notorius for problems.
Whenever I have a customer that is unfortunate enough to be stuck with one I always reccomend they replace it with a "Honeywell" or "White Rodgers" brand T-sat.
What kind of problems you might wonder?
Every kind imaginable.
If yours is not holding the set temp when you tell it to, it's probably not you, 99% chance the thing is simply malfunctioning.
Aug 29, 2009 | Heating & Cooling
Heating & AC thermostat problem
It could be running in a "programmed mode" if it has the capabilities. You could exit from the programmed mode
Mar 29, 2008 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
