Question about Samsung Televison & Video
How to hookup My Seiki tv to my samsung sound bar with no optical option on tv?
I have a Seiki 50 inch tv and I'm trying to connect my Samsung k-450 sound bar to the tv, but there is no optical in or out on the television. IS there another way that I can hook up my sound bar?
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
GadgetRaja
  • 150 Answers
SOURCE: 50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... rajanetworking@gmail.com
Posted on Sep 02, 2009
james tv man
  • 91 Answers
SOURCE: I have a 50 inch LG plasma tv, not sure of the
The optical output is always on.......you will see that the cable is lit up at the end when you plug it in........you may have to set your sound bar for the optical input though........do you have that manual?
Posted on Jun 02, 2010
alexander404
  • 276 Answers
SOURCE: I am attempting to attach a Samsung Sound Bar to
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Posted on Aug 12, 2010
walesarumi
  • 6993 Answers
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
Posted on Feb 26, 2011
Hi how do i connect a sound bar to my 43 in tv
Depending on the sound bar / TV configuration you can have various connection solutions.
The usual connections are HDMI, RCA and optic. Whichever route you take, consider what you want to achieve. For instance, I have a sound bar connected and use satellite as my TV source. Instead of connecting the sound bar to the TV, I opted to connect it directly to my satellite receiver as my receiver has this option. The reason I did this is so I can tune my satellite to a music station and play music through the home without having the TV on. No point of running the TV is all I want is sound.
G'luck!
Jun 16, 2016 | Seiki Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Trying to find out what type of sound bar that will work with my tv
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
Feb 26, 2013 | Hisense Televison & Video
I just purchased a new hisense 40 inch smart led television but I seem to have misplaced (thrown away) the manual. I am wanting to add a sound bar but I am unsure of what type to buy because I am unsure of...
its a smart tv it will have an optical plug in. I have a samsung sound bar and a 50" LG the samsung has a optical input on it. look on the back of the sound bar you will see two spots that have a rubber flap on it and say optical on it
Feb 26, 2013 | Televison & Video
I want to purchase the 28 inch TV - however when I reviewed the literature I couldn't figure out if our sound bar (Samsung model # HW-C451) would hook up to it - we only have a fiber optic connection...
Well before I can tell you if there is an adapter available, you need to tell me what kind sound outputs are available on your tv. Please provide this info so that I can tell you whether there is an adapter available.
Mar 27, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
