Question about Frigidaire Dryers
Why does my frigidaire dryer display Loc and will not turn on or off?
  • 50 Answers
Need model number. Could be child lock for the control has been activated.
Posted on Dec 08, 2016
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Im having a problem with my washer it won't work and its flashing loc
Good Afternoon Jesslyn, I am happy to assist you!
I understand your washer is not working and flashing LOC; however, I see that your question is listed under Frigidaire FEX831CS (Top Load Stacked Washer/Dryer). This specific laundry center does not have a digital display. May I please have your model number? You can typically locate the serial tag, on the upper front as you open the door.
In the meantime, if you have a front load washer, I suggest pressing OPTIONS and SELECT at the same time and hold for approximately 15 seconds until "LOC" is no longer displayed. I hope this helps!
Thank you - Z.
Apr 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not start. Has LOC error code.
Hello Luz - This is AP and I'm happy to assist you!
It appears your Frigidaire dryer console Control Lock has been activated. Without knowing your specific model number I can suggest to simply press and hold the Options and Select buttons at the same time until LOC is no longer displayed to deactivate the lock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
Mar 03, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Error code LOC ?
LOC means that the control lock has been engaged. (This feature also keeps a child from changing any setting when a load is in progress or starting the dryer with the cat in the unit.) On at least one Frigidaire dryer, press and hold the Options and Select touch pads for at least 10 seconds (until the display changes) to toggle the lock on and off.
Usually, the two keys to press for the Control Lock will have a line between them with a padlock symbol in the middle of the line. (This symbol will be in a very small font.) This may help you find the keys to press if other models of Frigidaire dryers use a different combination of touch pads.
I hope this helps.
Oct 24, 2013 | Frigidaire Electric Dryer
Dryer displays loc? Will not turn on
Well it's better if you provide the Brand and the Model Number information anyway if your dryer's door switch is defective, it will not allow your dryer to start. So first of all you can check your dryer's door switch. Also check start switch.
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Frigidaire Dryers
I am trying to use the dryer and an error code of LOC comes on and it won't run
The control is locked. Press and hold the OPTIONS and SELECT button at the same time for 10 seconds or until "LOC" turns off. To lock the control, press and hold OPTIONS and SELECT until "LOC" is displayed. Unplug the machine for at least 30 minutes if pressing and holding the said buttons does not unlock the control to eliminate the possibility of an electronic glitch. The control may need to be replaced if unplugging the dryer still doesn't solve the problem.
Dec 31, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Super...
The LOC flahes on my display, it allows me to pick a cycle but i can not start it. Please help, i tried to press options and select at the same time for the LOC to stop flashing...is there anything else...
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jun 19, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Loc Light Display
Try unplugging it, waiting 5-10 minutes, and plugging it back in.
Jan 03, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
60 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
